Page 1 of 3 123 LastLast
Results 1 to 20 of 58
Thread: Self Build - 18 x 36 Vinyl - Tallahassee Florida
    May 2017
    Tallahassee, Florida
    34
    I have lurked on this excellent forum for long enough. After about a year of planning, researching, and general second-guessing, I started my 18x36 steel pool build about two week ago. I am doing as much of the project myself as I can including excavation. Here are some picture of the excavation. Of course, a multi-month drought ended promptly after the rental backhoe arrived. I've started setting the walls, my deep end washed out pretty bad in the rain, so I'm a little concerned about the space that has opened beneath the deep-end center wall section (it is not fully set in place yet with stakes or fully bolted. I'm also wondering for a couple of areas where my walls are low, what do people use to get them back up to level? I've seen some photos where it looks like wooden wedges are inserted. I'm low less than 1/2" in just one two section area of wall.
    May 2017
    34
    Re: Self Build - 18 x 36 Vinyl - Tallahassee Florida
    Jun 2017
    HARTSELLE AL
    4
    Wish I could help. I'm about to be in the same boat. I'm thinking of dropping $150 on a large tarp to keep as much rain as possibe out, as I own the backhoe and expect to be slow enough to see a few rains. What are you going to put on the floor?
    Flybriz's Avatar
    Apr 2010
    Tulsa, OK
    43
    Wow, that's a big project! We just finished an on-ground build that was dug into a slope and had a similar issue - lots of rain washed out our hopper and created some voids underneath the walls. We mixed up some concrete and packed it into the voids, which helped some, but hard rains still managed to get underneath and create new voids. We added a french drain around the perimeter (which you may already be planning), and also dug a narrow channel around our walls and installed 12" aluminum flashing underground, vertically against the wall. This stopped all of the erosion. We also threw a cover pump into the hopper to keep it mostly dry - one with an automatic switch that turns itself off when there's no water left to draw. Best of luck - I know how frustrating it is to be constantly correcting your site due to weather.
    8k Aquastar On-ground, Pentair Easytouch 4, Intelliflo VS, IntelliChlor, MagicFalls, Globrites, Sta-Rite NG Heater, lots of wires and pipes that go somewhere...
    Sep 2013
    Nashville, TN
    398
    Wow, nice work. You will want to get the walls level, plumb and straight, then brace it good when you pour the concrete around the base. That should lock it in good for you. Once you have the bottom finished, liner and water in, it should be pretty well set.
    18x36 Vinyl, sports depth, 8' Roman steps at each end. Hayward 1.5hp 2speed pump, catridge filter, 2 skimmers, no main drain, 3 SR Smith Treo LED lights
    May 2017
    34
    Thanks for the feedback guys. It has rained pretty much everyday since I posted these photos. I'll post some updates. I've been content to work just a little at a time on whatever I can. When it's too muddy I focus on plumbing and equipment pad. I haven't poured my collar yet, just need a couple of dry days to recheck my walls and make sure everything is true and level. Because the backyard is a slope I'll be doing some serious grade work and a couple of smaller retaining walls (less than 24") we've also got two very large decks planned that will provide access from the house to the pool patio.
    I'm doing vermiculite on the floor (if I ever get that far)
    I've got the walls all the way around, just not the steps yet. I'll try to get an updated picture later.
    Plumbing trench to equipment pad. 24" below grade.
    Equipment pad. Going to start out with the sand filter that came with the pool kit. I upgraded to a hayward 1.5 pump, and bought a Circupool salt chlorinator.
    May 2017
    34
    got a bunch of work done on the equipment pad yesterday.
    a different angle to see the status of the walls. I'm hoping I can get the walls collar pour ready over this holiday weekend.
    May 2017
    34
    I'm satisfied with the walls and ready to do the collar pour on Friday morning. I'm within 3/4" of square and 1/4 of level. I see the main concern during the pour as being to keep the walls from moving inward (or at all) I was going to place some 2x6 bracing across the pool to aid in this. I'm open to any other advice on this. Updated photos attached.
    22k Gallon Inground Vinyl Liner Pool -Sand filter -Hayward 1.5hp pump - single speed - Pool build started Jun 2017 (self-building - under construction)- Circupool SJ40 SWG - Tallahassee, Florida.
    Casey's Avatar
    SW PA
    10,502
    Great job!
    May 2017
    34
    I checked out your project -- it turned out amazing! Nice work
    I checked out your project flybriz -- it turned out amazing! Nice work! I only hope mine turns out half as good.
    Jul 2017
    Tallahassee
    1
    Way to go, Chris! (And fancy running into you here).
    Sep 2013
    Nashville, TN
    398
    Seems like there were holes in the bottom flange to drive rebar through to hold them in place, also on the braces and that should do it
    Apr 2016
    west jordan
    39
    Quote Originally Posted by Sseaman View Post
    Mine had rebar hammered down 2 rebar in each panel on the ends where the panels joined. Also looks like you have an 'A' Frame support, mine had stakes in the back, I drove those down and bolted them. Once I had done the above I was surprised at how sturdy my walls were, they didn't move when I poured my concrete collar.
    Good Luck!
    May 2017
    34
    Got the collar poured yesterday morning. 2 of us did the whole thing in about an hour and half. The walls held very well with the steel stakes and the rebar and a couple of a 2x6. I'll update with pics soon.
    May 2017
    34
    Quote Originally Posted by anta_mireille View Post
    Mireille, too funny. Glad to run across another Tallahasseean who is getting into the pool world
    May 2017
    34
    Been working on plumbing and starting to backfill with fill sand. passed inspection on the concrete collar, next inspection is the plumbing pressure test. It's been slow going for the last few weeks with work schedule and weather, but getting their inch by inch. I'll update with more pictures soon.
    May 2017
    34
    I'm working on plumbing my skimmers, which are Aquagenie. They feature integrated returns and have a 2" glue connection for intake and return, included was a glue to thread adapter for each. I'm assuming some put a thread adapter for their connection to the bottom of the skimmers so that it could be more easily taken apart if leaking later, but it also seems to add a few solvent welds to the equation, for space and simplicity sake I'm thinking I'll just go straight into the bottom of the skimmer with my pvc to avoid the extra connections / adapters. Any thoughts on this?
    Also, to anyone who has installed aqua genie skimmers on a steel wall pool, should the front of the skimmer be flush with the pool wall? Mine stands proud about 1/2 an inch and my instructions mention (in only one spot) abs spacers for use with steel wall, these weren't included and aren't on the parts list.
    Apr 2016
    west jordan
    39
    Quote Originally Posted by chris_corzine View Post
    I put aqua genie on my pool, steel walls as well. I glued the PVC right into the skimmer. You should have some spacers that you will want to use in the back of the steel wall when attaching the skimmer. It should look like the back of this picture.
    19,000 Gallon 16x32 IG Vinyl Liner with Spillover Spa
    Hayward C2030 Cartridge Filter, Hayward Super Pump VS, Hayward H-Series 200k btu
    Aqua Plus PL-PLUS 40k cell, TF-100 test kit w/ speed stir, K-1766 Taylor Salt Test
    May 2017
    34
    Quote Originally Posted by broschb View Post
    Thanks for the info!
  20. Back To Top    #20
    May 2017
    34
    broschb -- I checked out your build, it's definitely an inspiration, helps me see the finish line.
