Thread: cracked/split liner
    Gardendale, Alabama
    15
    cracked/split liner
    OK, Now, Looks like we have a couple of cracks or splits in our liner on the steps. Actually the liner has wrinkles in it on the steps and that is where the split/cracks are. We had thought water loss was due to evaporation but it began getting a bit excessive even in this heat!
    Are there any products to seal these up without draining?
    I realize a patch would be best but if we can make do till later that would be great.
    And How difficult is it to patch a pool liner?
    Any input will be greatly appreciated and Thanks in advance.
    28k IG Vinyl, Hayward 244T Sand Filter, Hayward? 1hp pump, 3/4 hp booster pump,
    3-8 ft deep
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: cracked/split liner
    I'm assuming you have vinyl covered steps, (how about a picture just to make sure). Pretty much all adhesives designed for pool patching work under water. boxer glue works well with vinyl patches and anderson (leaktools.com) has a flexible sealer for small holes and cracks. Patching isn't hard just press out the bubbles and smooth out best you can.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Gardendale, Alabama
    15
    Yes on the vinyl covered steps. Sorry no pic. Thanks for the info. So that stuff available at pool shops, or hardware stores?
    And again Thanks
    3-8 ft deep
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Pool stores have them, you can also order online.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
