Thread: Best tool/method to smooth rough plaster around edge tiles?
    Aug 2008
    Maryland
    18
    Our newly plastered (6/26) pool, while generally quite smooth (sort of like leather), has some rough areas near the edge marker tiles, I think due to being roughed up by the sponge as the plasterers cleaned off the tiles. We are steadily brushing, but it seems to have little effect on these areas, so I'm wondering if there is a tool/method to 'sand down' the rough bits?
    thanks,
    Bcatv
    52k gal/1300sqft white plaster wi spa, 2 Intelliflo 4x160, 2 C&C 420, Heat Siphon heat pump, PCC-2000, Intellitouch, CL&MA injection
    34
    Re: Best tool/method to smooth rough plaster around edge tiles?
    Let it cure one month before sanding then use a masonry disk for a 4 inch grinder. Just lay it on its side and sand it smooth.You could also get a rubbing brick(the one with red or blue handle) at Lowe's or Home Depot. The trade Pro's use diamond sand paper(old hydra-torque pads).
    Frank
    PebbleConcepts.com
    Aug 2008
    Maryland
    18
    Thanks Frank, hadn't thought about the masonary disk. Will try that after the first month.
