Thread: Pump Loses Prime
    chris732003's Avatar
    Baton Rouge, La.
    2
    Pump Loses Prime
    Pentair Sand Filter
    3/4 Hp Pump
    IG Fiberglass
    20,000g
    Trying to vacum up dead algae. Vacum through skimmer w/ basket. Pump loses prime in every 2 min. Thinking something is clogged, placed garden hose in line to try to free debris. Didnt work any suggestions on how to free clog from skimmer to pump. (Dis. 20')
    Mar 2009
    Glendora, California
    169
    Re: Pump Loses Prime
    Does the pump still lose prime if you run it without the vacum attached?
    18k Inground Plaster pool / TriStar Variable Speed Pump and Controller
    48sq ft Hayward DE filter/ Swim pure Plus 40k cell / Kreepy Krauly
    Solaxx Ph-Tek
    Baton Rouge, La.
    2
    No it doesnt but the basket does take a while to fill up.
    Mar 2009
    169
    I doubt this is your problem but it wouldn't hurt to check. Some pump skimmers have drain plugs. You may want to see if yours does and if so make sure it is snug and the O ring is in good condition.
    To check your intake line, you can try and run a snake through it and see if it gets hung up along the way just to be sure it is clogged.
    Solaxx Ph-Tek
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    A clog may be the issue but an easier thing to check is the connections on the vacuum hose. Often one cuff will swivel if you try to turn it, the other will not - you want the end that swivels on the vac head, the swivel on it will draw air and kill the prime if attached to the skimmer plate
    Switch the vac hose around and see if the problem disappears 8)
    Also, do you prime the hose first? If not - you have to
    Luv& Luk
    -Ted
