Results 1 to 12 of 12
Thread: Christmas in July???
    Guest
    Time to replace my 26 year old equipment.
    Hayward Pro-Grid 48 sq ft.
    Hayward RS 1500
    Stupid Cat.
    Edit - Ok i noticed i have a 2hp magnatek on it, its pretty old. Is it that big of a difference between the 2hp and the 1.5hp.
    Guest
    What type of replacement do you have in mind for the cat and will it be an inline or offline cat?
    Ft Lauderdale, Florida
    1,462
    Brett,
    Look for the Service Factor (S.F.) on the motor label. If you multiply the HP x SF = net HP.
    If your 2 HP has a .9 SF, your net HP is 1.8 HP
    If your 1.5 HP has a 1.2 SF, your net HP is 1.8 HP
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    A 2hp would be too big for that size filter, actually to be honest that pump has a higher flow rate than that filter is rated for. Someone can go to haywards website and pull the numbers.
    Guest
    Humm
    Just talked with my boss and he said,
    Your magnatech is ANCIENT
    The hayward RS moves way more water. So the 1.5 is more than enough. For mine he said he usually tells customers to get the 1hp. So im good
    Like I said I don't actually think you are good. He normally sells the 1hp for a reason because the 1.5 is more than the filter can handle. That pump at 40ft of head does 114 gpm. That filter has a design flow rate of 96 gpm. So what does this mean? Your filter won't be able to handle the pump. You either need to downsize the pump or upsize the filter. Downsizing the pump will save you electricity, upsizing the filter will save you water.
    any particular reason you're replacing the filter? from an appearance standpoint, it looks great. mine is 27 years old, took it apart last year and laterals are in excellent shape, casing, valve is in great shape. i took out the sand to remove and inspect the laterals and loaded it with zeobrite and it continues to work great. it's the one piece of equipment i did not replace. i did replace the pump as it was getting noisy and likely was on the way to needing bearings. i might have got a season or 2 more out of it but got a good deal at the right time so thought what the heck.
    • 15K IG gunite/plaster pool • Pentair: Whisperflo EE 1 HP • Nautilus FNS + 48 DE Filter • IntelliChlor IC40 •
    • Spectrum Amerlite SAm • Admiral S20 Skimmer - Circular Weir • Kreepy Krauly •
    Quote Originally Posted by tenax
    ps- is that the new filter in the picture which would explain my appearance comment..but then, i would be wondering why you're asking if you've already bought the stuff
    Guest
    who said i paid for anything :P anyways The old filter is nasty. Leaks everywhere and is rusting plus all the grids are busted.
    AHH..so that was a new one then...i thought..****, that's good looking for a 20+ yr old filter
    Guest
    Btw this house was given to me LOL. Parents never kept up on much. Whens the last time anyones seen a coper pump :P
    Edit * Darn new keyboard :P
    Guest
    Quote Originally Posted by poolio
    You gotta factor in the elbows the piping etc.... When it comes down its probably gonna push 95 gpm, it will be fine.
