What do you use to measure liquid chemicals?
97 cent plastic kitchen measuring cup from Walmart here.
Pyrex (or any glass) near the pool is not a good idea. If you drop and break it, the slivers that land in the pool will instantly disappear. At least until they stab into someones foot. :shock:
For adding muriatic acid, I use a plastic measuring cylinder from Pampered Chef. It has two parts. The inner cylinder has a pour spout and is made of thick plastic similar to the material from which a muriatic acid bottle is made. The external sleeve is non-slip clear plastic with both wet and dry measured markings.
I need to get me one of these measuring cups everyone has. Today I have a bucket that was originally frozen Margarita mix with sharpie marks for quarts. I just do the math for number of cups in a quart. Measured the marks using a plastic Rubber-made tea pitcher with tap water.
