Thread: Brick Coping on vinyl pool question
    awarsoca's Avatar
    May 2009
    Columbia, SC
    64
    We opted for a brick coping on our vinyl (pics will be up later). They used Lexel to attach thin paverson top of the metal frame and then used thinset to attacht he brick to the pavers and then grouted the brick. When you are in the pool you definitely can see some gap between teh brick and the plastic where the liner is attached. Should this be caulked? or do I just leave it as is?
    Thanks
    Clint
    Pics of the build process
    34x16x25 Lagoon IG Vinyl 14,800gal (Oxford Tile/Glimmerglass 20mil)
    Pentair: Intelliflo VS3050 pump, Intellichlor IC40 SWG, Clean and Clear 320 cartridge filter, LA01N 3/4hp booster pump and Polaris 280 cleaner
    awarsoca's Avatar
    May 2009
    Columbia, SC
    64
    Re: Brick Coping on vinyl pool question
    Second question....do you but the concrete right up to the brick or do you add a foam buffer strip?
    Clint
