Thread: High Alkalinity
    Wichita, KS
    5
    High Alkalinity
    Hello!
    New pool owner here. Getting everything balanced, and I'm getting really close on the proper chemistry. One item I can't seem to get back down is the Alkalinity. It's over 200. The test strip says 180 is high.
    I've been looking through here and haven't found a discussion that specifically mentions high alkalinity, so I thought I would pose the question.
    Thanks for any help!
    Feb 2008
    Denton, TX
    5,062
    Re: High Alkalinity
    Greetings!
    First off, test strips other than for measuring salt or borates are unreliable. You need a good test kit. The TF-100 (link in my sig) or the Taylor K-2006 are good.
    For total alkalinity correction, try this: pool-school/lowering%20total%20alkalinity
    Wichita, KS
    5
    Re: High Alkalinity
    Yeah, I was hoping to get back here to remove my post. I was looking at that exact article. I should rephrase my question: Short of all my other numbers looking good, will high TA (as I understand it to be now) cause any sort of problems to people swimming if that's the only level I'm seeing high. I was reading and it was saying to get the neighborhood kids in there and get to splashing.
    Much appreciated.
    37,887
    Re: High Alkalinity
    High TA doesn't cause any direct problems. What usually happens with high TA is that the PH goes up fairly rapidly, and high PH can cause problems.
    Wichita, KS
    5
    Re: High Alkalinity
    That's what I had thought, based on the article on how to lower it. Appreciate it.
