about to order the test kit
Jul 16, 2008
35
smithfield VA
i'm about to order the complete test kit as recommended in pool school, but since I have a swg on the way, i guess i need to order the salt test strips as well. there are only 10 in the pack, is one pack enough? how often will i be testing the salt level?
eta: this is what is says in the article
In the spring, mid-summer, and any time there has been substantial water replacement
If you use salt, test the salt level and adjust if needed.
but since i will be setting up the salt system I assume I'll be testing to make sure it's all ok.
