Hey Everyone,
What a great resource this is! I've had my pool for 2 years now and have literally learned everything through this site and you helpful contributors. Thank you all for sharing this knowledge as the things you are told from pool builders, pool stores, and pool cleaners tends to be less than helpful.
I would like some guidance on a few things that I can't totally figure out:
Levels:
Salt- 3200
FC- 2.5
CC- 0
PH- 7.2
CYA- 70
Calcium- 700
Pump runs 4 times a day for 3 hrs each time mostly for skimming purposes since theres no screen.
I know it is recommended to at least have a cell thats double the size but I didn't know that when building. My builder installed a Hayward Blue Essence t-5. Last summer in the SW FL sunshine it provided chlorine just ok. This summer its really struggling (ran for 24 hrs at 100% and only got up to 2.5 fc). I do clean it every 3-5 months (with acid only as needed). The last cleaning was about 2 weeks ago and i forgot to turn the power off when i dumped what was probably too strong of a mixture. More like 2:1 instead of 4:1. Could I have fried it by doing this with the power on? It had no flow so should've been off I would assume. In the middle of a slam right now to be sure there isn't an unnoticed bloom occurring. My question is; Can I/should I install a t-15 and if so, is all I need to do is change the setting on the control panel from t-5 to t-15?
What I think the diagnostics are for the cell. I only know what the 3200 and t-5 are:
3200
88
32.8
0.0
100p
- 0
AL-0
R 1.59
T-5
The next question might need to be in the pump section of the forum so please let me know if I should repost...
I would like to control things with my smartphone. I'm not sure where to start on this. Is it as easy as just switching to the Easy Touch or is this a can of worms I don't want to open or pay for? I was thinking of installing a wifi switch prior to my pool light control so that I can at least control my pool lights but it would be nice to control everything.
Thanks for everything!
Levels:
Salt- 3200
FC- 2.5
CC- 0
PH- 7.2
CYA- 70
Calcium- 700
3200
88
32.8
0.0
100p
- 0
AL-0
R 1.59
T-5
