Thread: Still a newbie
    Phoenix, AZ
    24
    Still a newbie
    Well I started off with a green pool. It is now in swimming condition. However, the FC levels will drop 4-5 ppm per day. I don't think its sunlight doing the damage because my CYA is fairly high. Any suggestions?
    FC 1.5 (but I just added more)
    TC 1.5
    PH 7.8
    TA 140
    CH 270
    CYA 60
    Also, I have noticed that some of the return 'eyeballs' in my pool aren't aimed for the best circulation. Mainly the one closest to the skimmer. It's aimed towards the surface which knocks all of the floating stuff away away from the skimmer. So I tried to aim it down lower and it seems pretty well stuck. From what I've found here and other places on the web, they should be pretty easy to adjust. Just wondering if anybody can offer some advice on how to adjust and/or replace these returns. Here are some pictures, the second one has some tabs that look like a special tool is used to turn it and 2 of the 3 returns in my pool have those tabs.
    ~10K Gallon, IG, Pebble, Sand Filter, Variable speed pump, Spa, Pop up cleaners
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Re: Still a newbie
    I stuck a screwdriver in mine to get it to move. Wasn't my favorite tool of choice but it was all I could think of at the moment and it worked. Something made of plastic or wood might be better.
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Still a newbie
    Quote Originally Posted by deez
    TC 1.5
    PH 7.8
    TA 140
    CH 270
    CYA 60
    You should do an overnight test. This will let you know if you have organics in your water.
    With a CYA of 60 (not really high for Phoenix) your minimum FC level is 5 and your target FC is 7 to 9. So your FC should NEVER drop below 5.
    Check out the Chlorine/CYA Chart (in my sig & Pool School) to help understand the relationship.
    You're done SLAMing when:
    Arizona
    924
    Re: Still a newbie
    Deez, Butterfly is right. You may not be quite done shocking to get rid of all algae.
    Also, how long are you running your pump now? The temps in Phoenix are now running well over 100 to 109, and IMO you may need to run your pump between 10 to 12 hours, daily.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Phoenix, AZ
    24
    Re: Still a newbie
    Yeah, I think I'll go back to shocking for awhile until I don't lose all the free chlorine over night.
    My pump is going around 14 hrs a day.
    Also, since I posted about those returns. Is there some easy way to connect a pvc pipe to those outlets, with or without removing the eyeball? The pool water is around 88 and getting too warm for my liking. I've seen some creative evaporator setups that I would like to try. I'm pretty handy with the actual pvc work (i.e. potato guns) but not with connecting them to a pool.
    And yet another tangent, my pool does have a built in aerator, but the ball valve handle is broken and I can't get it to turn any suggestions on that? Sorry for so many different questions.
