I replaced pentair challenger pool pump with identical pump. Old pump also had some leaks in lines. Installed new pump with existing pipes and it was running somewhat smoothly but would lose its prime after a bit which I assume was due to the leaks. Pump also changed sound but continued to run just had more of a screech to it rather than the quiet operation when it started. So I tear out all of the old patchwork pipes from previous homeowner and build out new, which still had a small leak at old valve. Long story short I got a new valve and have replumbed. Turn on pump and it pops and now only buzzes. It sounds like maybe the capacitor has failed. My question is what would cause this to fail for such a new pump? Is it possible I wired it incorrectly? Everything I read said it did not matter how it was wired and I connected same wires to same terminals in old pump. That plus it was running smoothly when I first switched it out. Luckily if it is just the capacitor then I have the old one from previous pump and can swap them out, just want to make sure I do not blow this one as well. Thanks in advance for the advice.
