Helping my dad and trying to get him to stop going to the pool store and wasting his time and money
So I brought my taylor kit over and did some measurements:
PH: 7.0 (maybe lower/off the chart)
CYA: 60ish
TA: 130 (high)
FC: 0.5 if that
CC: 4.5
What was confusing was the app says for TA of 130 that you reduce ph to 7.0-7.2 with acid and then aerate to increase Ph.
Since his pH is already low and his TA is still high, what do I do?
We took his pool pump (he has no water fall and his jets dont angle up enough to make anything more than a ripple in the water) and put it on the stairs so that it created a little above the water turbulence in hopes to raise the pH
However, the question remains - what is the proper next step before SLAM? Should we get the pH up first? What about the high TA - do we worry about that later?
It seems he is having difficulty keeping FC and I presume that is because he needs to SLAM - but i also thought one doesn't SLAM until the pH is within a normal range....does one also have to wait for TA to be within range?
His color is cloudy blue/green at the moment, so fairly certain there is still tons of algae.
thanks as always for your help!
Dad's pool info:
Vinyl, ~36k gallons, Temp ~60 degrees and sand filter.
CYA: 60ish
TA: 130 (high)
FC: 0.5 if that
CC: 4.5
Dad's pool info:
