Thread: Water Shooting out of Waste pipe while set 2 Filter
    Water Shooting out of Waste pipe while set 2 Filter.
    I have already replaced the Diverter and gasket....
    Could this be because of sand levels I am out of ideas.
    Jun 2008
    Central MD
    149
    Re: Water Shooting out of Waste pipe while set 2 Filter
    What happens when you set it to waste?
    I am thinking something got put back together incorretly.
    24' Round Doughboy AG.
    Usually filled with 3 kids, the wife, and occasionally the dog.
    It still shoots out as normal when set to waste. It comes out of the waste valve at about 1/3 of the rate when set to filter.
    Mar 2009
    Manitoba, Canada
    19
    Quote Originally Posted by tdroll
    I had this same problem. I also replaced the gasket and divertor, then the whole top, still the same problem. I ended up having to replace the valve assembly (not sure if that's the right name for it). This is the part that sits right on top of the filter container with the inlets and outlets. This fixed my problem. It must have been warped or damaged to the point that the gasket couldn't form a seal. I have a thread about this under 'Pumping Station'. Do you have a heater? Apparently running a heater with the pump off can cause warping and other damage to the punp and filter.
    21 foot AG 10,000 gallon, Waterway pump and Waterway Carefree 19" sand filter
