I learned a lot on this forum years ago - so much so I haven't been here in years & had to create a new account (could not figure out the old one). Pool has been crystal clear since I converted from the evil Baquacil years ago and (mostly) use the BBB method. But, I now have an issue I haven't encountered before.
I recently opened up our pool. I have a clear pool - but the water is tinted green. From reading around, I fear that it is from an algecide. I could kick myself. I never use algecide except when I first open the pool. But I bought the wrong kind - I mistakenly bought one with copper. Instead of returning, I used it - but just a small amount (2-4 oz) - figuring I'd never use it again all season & that it would not make a difference. I'm afraid that is my problem but want to check here.
Using a taylor test kit, my readings are as follows:
FC: 1.6
CC: .2
PH: 7.2
CYA: less than 30 - that's the lowest reading on the vial but I have to fill it up past that to get the black dot to disappear.
I generally don't test for CH b/c I have a vinyl pool. I generally am bad and don't test TA either. If that's necessary I'll re-test. If it is metals, is my only option to replace my water?
I use liquid chlorine 12.5% for sanitizer/shock. I've been adding a gallon daily. Over the weekend, the pool was actually clear. We finished vacuuming, skimming, etc. to get the rest of the leaves out. It looked great and when I looked out an hour later it was this light green color! I assumed perhaps I had let the chlorine get too low so shocked it with two gallons of the liquid chlorine. tested the next day & readings were similar to the above. I added another gallon yesterday and today. My husband thinks the vacuuming changed the color! LOL!
I know the PH is on the low side & CYA is too - but would that make it a green tint? I've added baking soda to raise the ph.
And, how do I test for metals to see if that's the culprit? DO I need to get a pool store to test for that? Ugh.
Thanks in advance.
FC: 1.6
CC: .2
PH: 7.2
Thanks in advance.
