Hi,
I opened my pool a week ago and it was green. Added a good amount of chlorine (which helped) and then added a chlorinated shock 2 days later. The water became blue but still cloudy.
The test strips I have showed appropriate levels of Total Alkalinity, PH and Total Hardness; but extremely low FC and TC (although I had added a lot of chlorine as mentioned earlier).
On the advice of a neighbour, I added in alum (acts as a floc?). Followed the instructions for adding in a floc, but now 48hrs later nothing has settled down (or very little of it has, since I can't really see the bottom of the pool it's tough to tell).
After reading the forums, I now realize that adding floc wasn't necessary; instead I should have balanced the water chemistry and slowly got the pool clear through filtering. Also that I need a proper test kit and that pool store tests and test strips are unreliable.
Assuming what I've said above is correct, I have a few questions:
1) When floc is used, it is advised to vacuum on waste, not on filter. What is the reason for this? Not a lot has settled and I'd rather not put it on waste, so will I ruin my filter by running it now with the floc in it? (aka ditching the floc method once it's already added in). I'm trying to get the pool started, fix the chemistry and run it, but the floc (that didn't work) is making me reluctant to do so.
2) In the meantime while that I get a test kit, is it worth testing my CYA level through a pool store and using that as a ballpark range?
3) Any recommendations for test kits in Toronto, Ontario? (local/online)
Also, I should mention that I am progressing through Pool School right now.
Thank you so much!
Thank you so much!
