Thread: advice on pump, filter
    Aug 2007
    Central Illinois
    38
    I've been around this forum for a couple of years, mostly just reading and learning. We started out with a large Intex easy-set to "get our feet wet" and had great success with it, apparently contrary to what a lot of people experience. Earlier this summer, we started the ground work for a traditional above-ground pool. The ground work is approaching completion (if the rain stays away), so now we're contemplating the next steps.
    The setup we currently have sitting in the barn is a ten-year-old or so used AGB from a dear friend. It was taken down from their place in April, and everything was in working order when the pool was closed last fall. This is what we have...
    18'x33'x4' (15,700gal) pool, minus liner of course...it's in pretty good shape, but some of the buttress assembly got a bit beat up when the folks helping my husband take it apart got into a hurry
    1 hp A.O. Smith Century pool/jetted tub pump
    Part (model?) number 340197
    3450rpm
    Purex triton sand filter
    TA-50/50d
    flow rate = 50gpm
    media = #20 silica sand, 225 lbs.
    max working psi = 50
    What I'm most interested in are your opinions on are the pump and filter. Is this pump and filter system adequate for a 15,700 gal pool? We're willing to purchase what we need, up to/including a whole new pool, depending on whether my husband feels that he can get the current pool put back together.
    Thanks for any advice.
    Nikki in IL
    18'x33'x52" AGP, 1.5hp Hayward pump, 200# Hayward sand filter, Aqua-Trol SWG
    "Intex graduate" from a 5400 gal, 18'x48" Intex quick set, crystal clear everyday (with the original Intex equip)for 3 seasons thanks to TFP and BBB
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: advice on pump, filter
    as long as the pump still works and the sand filter laterals are in good shape...keep what you have...load it up with 225lbs of fresh sand and you should be just fine. 1hp is more than enough and 225lb filter is OK...for reference I have a 250lb filter and a 1/2hp full rated pump...we have about 2000 less gallons than you, but my filter is slightly oversized...again as long as your equipment is in working order, I think you will be just fine.
    Aug 2007
    Central Illinois
    38
    Is there any kind of chart that lists pool size/gallons and the size filter and pump recommended (I did check pool school and didn't see what I'm looking for)? Just trying to figure out if I'm "close" on pump/filter size, etc.
    Nikki in IL
