Hi George. Just a quck check-in on lunch
1. Pool skim is awesome, I use one and it really helps
2. Slimebags are reported to be great for polishing water - I only meant that its not necessary. Didn't mean that it wouldn't be a nice addition. It might help you catch stuff
They do capture to 1 micron. Sand filters capture to about 30 microns. DE to about 5 microns. But my robot filter goes to 5 micron so I haven't bothered with the slimebag personally. I only have 3 returns, one s used by pool skim, one on my steps, so I prefer to keep the deep end one wide open.
3. Run time on filter is usually determined by water turnover (eg how long it takes) and a bit of experimenting. Most systems are designed to turnover volume of water once every 8 hours on full flow.
I'm an advocate of heavy filtering, as I feel it helps avoid problems. I run my own filter 24/7 due to forest border and heavy debris traffic that I prefer is skimmed by skimmers as opposed to dropping to the floor.
BUT I've also now upgraded to a variable speed pump in order to do this economically.
I AM A MINORIY on TFP in terms of filter fetish. Many people have great success with very short filter run times. You do not need to do as I do by any means, especially if you have higher electric rates. I just really prefer my water moving.
However, given the trouble its taken to get you clear, you might want to start with filtering sunup to sundown for a week, then slowly decreasing your run time each day to find the happy place between sparkly water and your wallet
