At wits end: Algae buildup
Jun 30, 2015
12
Southlake, TX
So i am at my wits end and have no idea what i am doing wrong. So far this year, I absolutely can't get rid of algae an i feel like i have tried everything. I started to notice some algae on the walls of the deep end in the sun so i thought i would nip it in the bud. I tried slamming the pool for several days and felt like it was getting better but it really wasn't. I started to think that it might be a calcium buildup since mine was pretty high. That led me to try and lower the pH while keeping the chlorine pretty high and try to brush the buildup off with a wire brush. Still no go! I have been consistent with brushing each day and staying on top of the chlorine but i am at the end of my rope. Please provide some help because i want to just fill the pool in.
This pool is not the best design and is too simple of a design. Only one skimmer for 28,000 gallons but i have added a robotic cleaner and a skimmer on one of the returns. Lastly, I live in Dallas, TX and it is beginning to warm so i am concerned about trying to empty and refill the pool.
FC - 11
pH - 7.4
TA - 100
CH - 625 (used cal-hypo to slam)
CYA - 65
fny,
If you are SLAMing your FC is waaaay too low for your CYA level.. With a CYA of 65 (rounded up to 70) your FC needs to be about 28 to get rid of algae..
See this chart... https://www.troublefreepool.com/content/128-chlorine-cya-chart-slam-shock
Just so I can make sure we are all on the same page, what do you normally use to chlorinate your pool? And what test kit are you using to get the results you posted?
Here are the instructions on how to SLAM a pool.... https://www.troublefreepool.com/content/125-slam-shock-level-and-maintain-shockingl
When you brush this "algae" does it just go poof and go everywhere like dust, or not. I am by far not an expert in this area, but it looks more that a stain or scaling issue in the pics..
Let's see if we can get opinions from some of our other members...
I am not still slamming the pool but had previously done it and knew what level to do. My pool has no heater and I have never tried algaecide. Using a wire brush takes a minimal amount but I have tried brushing to no avail. I have wondered if it was some stain or scale but I don't even know where to begin with it.
I use the TF-100 test kit for my pool testing. I have no heater or any metal in the pool and the water is not from a ground well. Is there another way to test organic stains besides holding a puck to it? I don't have any and definitely don't want to purchase any. What is OCLT?
I have no metals in my water source either, but had some iron (water turned green ish) out of now where when I added
chlorine the first day this year. It can occur even if it makes no sense. So I roughly replaced half the water
and the water turned clear again.
It does sound like some sort of metal staining, but I could be wrong.
At least you don't have to slam.
I dunno. That looks an awful lot like the algae I've battled in my pool. Water column is perfectly clear - it only grows on the sides (less sun), disappears with elevated FC, comes back at recommended FC target. Even with aggressive brushing, a little brushes off (you seen a tiny algae colored cloud), but the plaster does not fully come clean even with hard scrubbing.
People are telling me it sounds like mustard algae. FWIW, I completed a slam recently, and then did 24 hours at elevated Mustard Algae shock level. Still didn't eradicate it - started reappearing a few days later at target FC. I think I've resigned myself that I'll need to hold FC towards the upper end of the recommended range to keep it at bay, as it seems immune to normal FC.
Well, I tried the Vitamin C trick to check for iron and I would say the results are inconclusive. It looked like it faded some, but it did not disappear so I still don't know. My situation sounds a lot like Jeff's. It fades slightly during slamming but gets dark when the pool is held at target FC. I am close to giving up and calling a pool service to see what can be done.
Pool company is probably going to suggest an acid wash, so you want to do everything possible to resolve it yourself. Obviously pictures are a hard way to diagnose, so most of what we are doing is guessing and trying to guide you through identifying the issue.
Does the stained area feel different from the rest of the plaster? Smoother or rougher? Smoother might indicate the plaster is thin or gone, while rougher might indicate calcium scaling. Calcium scaling will stain which can make it hard to recognize.
To determine if you have an organic stain place a trichlor puck on the stain for a few minutes to see if it lightens or removes the stain.
