Thread: Is there an optimal time to replace vs. repair?
    brauh01's Avatar
    Jul 2012
    Yardley, PA
    69
    My first pool. Pool is 10 years old. Have Polaris 360, which was originally installed. Two summers ago, I rebuilt using Polaris's rebuild kit. Four summers ago replaced all attachment hoses. Now, the top housing has cracked and split. Replacement top on order. With a Pebbletec pool, fine pebbles usually have to be removed from gears at the beginning of each season, so the cleaner is taken apart at least once every year.
    So, here's my question. Does chlorine over time lead to degradation of the plastic such that there is a normal life cycle, and should I be considering a replacement? I'm reasonably handy and don't mind an occasional fix. I also don't want to waste time if I should be looking to swap out. I'm certain there is no right or wrong answer, but am interested in others experience.
    Thanks!
    Bill
    23,500 gallon IG plaster with pebbles, Pentair FLT FNS 60 DE (160 GPM flow rate), Pentair Model 320 in-line Chlorinator, Jandy Plus HP 1.5 HP pump replaced with AO Centurian 1.5 switchless motor; Aquacal Heatwave heat pump. Method: since 2012 transitioned from "pool-stored" to TFP! Get your test kits here: TFTestkits.net correct link for pool calculator: http://www.troublefreepool.com/calc.html
    31,150
    Re: Is there an optimal time to replace vs. repair?
    If it's in the budget, trade that cleaner in for somewhere around a $1K robot (for that size pool). You will never look back.
    That said, if you are OK with the fixes, you can probably keep the 360 going for a long time but you are consuming 10x the electricity of a robot.
    Quote Originally Posted by brauh01 View Post
    Thanks!
    Bill
    Cleaning Housings/ casings seem to last about 10 years before the UV make them brittle and they crack.
    Im sure the Chlorine contributes some but its mostly the UV.
    UD
    20K Gallon Gunnite pool/900 Gallon in ground Spa/2HP WhisperflowSpa
    Pentair Master temp 400/Hayward Sand WZeobrite/Jandy RS-8 Aqualink/Jandy 2HP Epump
    12 - 4x10 Panels/Zodiac G3-T5 / BBB
