Thread: Ok to have eyeball return facing straight down?
    Jul 2013
    Long Island, NY
    577
    Is it ok to have my eyeball return facing straight down? The reason for this was because my solar cover was spinning like a record when I had the eyeball return facing to the right. It would bunch up around the ladder. I realize it won't filter as well straight down but that's ok because I dont get a ton of dirt and debris in the pool. My main question is will the water circulate enough for the spread of chemicals and chlorine? Or should I just live with the solar cover spinning. Or maybe angle it mostly down but a bit to the right?
    Gallons: 5000 Gallons
    Pool: 15' Saltwater 5000
    Filter: Pentair 1 HP Optiflow Pump w/ Clean & Clear 75Sq Ft Cartridge Filter
    SWG: Intex CS8110
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Re: Ok to have eyeball return facing straight down?
    Go with mostly down but still angled so that you get circulation. If there isn't at least a little bit of water circulation the skimmer won't work well to pull stuff off the surface of the water. You can also try attaching a line to the solar cover so that it cant spin with the water.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Casey's Avatar
    SW PA
    10,515
    Turn it down and to the right. If it's breaking the surface, the cover will spin.
    Jul 2013
    Long Island, NY
    577
    thanks. what do you mean 'add a line' How would I do that. It just sits on the surface of the water and doesnt have any grommet holes
    SWG: Intex CS8110
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,759
    https://www.amazon.com/uxcell-Metal-Single-Round-Punch/dp/B00ARBDBS0#
