Thread: Green Dust on bottom on a SLAM
    paulmaz's Avatar
    Apr 2016
    San Antonio, TX
    121
    I am in the middle of a SLAM, maintaining appropriate FC, brushing daily. Water is still blue but cloudy, and FC usage is still kind of high. The last two days I have green dust on the bottom, which I am brushing up to mix in to get filtered. My question is, is this dead algae? Just making sure I still do not have live algae, because I have been slamming for almost 5 days now.
    thanks,
    -Paul
    15k gallon IG plaster, 26x39 at widest points, sort of shaped like the great state of Texas!
    Pentair 342001 SuperFlo VS Variable Speed 1.5HP motor
    Tagelus TA-60 Sand Filter, Polaris 280, TF-100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Green Dust on bottom on a SLAM
    Yes, that sounds like dead algae to me.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,155
    Keep Slamming. You are making progress, but please don't fool yourself into stopping before its finished like so many people do and then complain that the algae is back, when it was never completely gone in the first place.
    No matter what anyone may tell you, the Slam isn't finished until your water is perfectly clear, the pool clean and you pass the FC, CC and OCLT tests.
    Quote Originally Posted by paulmaz View Post
    thanks,
    Divin Dave,
    Camp Pool Guy's Avatar
    Oct 2016
    New Milford
    12
    thanks,
    I'm fighting this same one ... my issue appears to be overly large quantities of POLLEN (PA Campground in the woods--even our roads are visibly pollen covered). Just keep vacuuming frequently ... at least (for my time and effort) it vacuums out easily (although it is a filter clogger of the highest magnitude) (I backwashed 4x in yesterday's 3h vac sesssion.
    Richard
    InGround,30x50, 50,000G, PVC on Concrete
    Tandem Filtration 2 x Hayward 2HP Superpump
    1 x Hayward S270T -- Fiber Clear Enhanced 1 x Pentair NSF72 DE -- Fiber Clear Media Used
    Lars Jandy XL3 Oil Fired Heater 1 x Hayward Booster Pump on Home-Grown Solar Heater (which does the job)
    paulmaz's Avatar
    Apr 2016
    San Antonio, TX
    121
    thanks everyone, I have no intention of stopping the SLAM until all three criteria are met, just wanted to make sure I have progress!
    As far as pollen, we are pretty much over that here in South Central Texas. It was really bad in March and April. I used skimmer socks (hair nets) and was changing them daily.
    -Paul
