Thread: Flooded Pool
    Jun 2007
    Corpus Christi, Texas
    12
    Flooded Pool
    Well I remember that there is no such thing as a stupid question so here goes -- Are there any concerns I should have with my pool flooding over with lots of rain? We've had a lot of rain the last two days and my in-ground fiberglass pool has flooded over. I know that there are water table issues and popping out of the ground but I see no evidence of that. The pool has a cantilevered flagstone deck over about 4" of concrete that is tied by rebar to the pool. The deck is three foot wide in most places and up to 6-7 feet near the slide and patio. The pool sits in sand, I live on an island, and the water table is usually about 7 feet, my deep end is six. Maybe just newbie jitters but thought I would ask. Attached a picture taken in drier times.
    16x32 fiberglass pool
    1.5 hp pump
    cartridge filter
    solar heater
    Dolphin Diagnostic
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Beautiful pool. Do you mind if I add it to the slideshow?
    I wouldn't be concerned about the water table. If your pool were empty, that is when you would need to worry about it popping out of the ground.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Jun 2007
    12
    Please do. Thanks for the quick reply!
    1.5 hp pump
    cartridge filter
    solar heater
    Dolphin Diagnostic
    If the water level is above the top of the skimmer opening then the skimmer won't skim. Nothing will really go wrong, but there will be more debris left on the surface than usual. Other than that you should be fine.
