Results 1 to 11 of 11
Thread: AB vs DB quotes - feedback requested
    Mar 2017
    Brooksville, FL
    57
    I have finally received quotes to resurface my pool (12x24 rectangle, gunite, 1999 in Florida).
    Diamond Brite - $3655 (most recommended DB guy in my area)
    • plaster - $2400
    • new 6x6 waterline tile - $1005
    • replace light w/Pentair Amerlite - $250
    • glass tile to outline steps - $0. Won't do it.
    • glass tile for markers - $0/labor. I buy the tile, they'll simply press it into the fresh DB.
    aquaBright - $5525 (says he has done 100+ AB pools in Tampa Bay region)
    • AB - $4000
    • new 6x6 waterline tile - $945
    • replace light w/Pentair Amerlite - $330
    • glass tile markers & steps - $250
    Concerns
    • The DB guy says they will grind off the face of existing tile and install new tile over that so tile and new DB are flush. Is that common?
    • DB guy buys a base color and adds quartz, etc instead of buying factory mix colors.
    • Not comfortable with glass tile markers not installed w proper thinset.
    Any thoughts, questions and/or comments?
    Thanks!
    screen enclosed 12 x 24 rectangle 10k IG gunite with AquaBright (Blue Lagoon w/Blue Med markers), Pentair CnC RP 150, Pentair Superflo VS (no SWG, no water features, no heater)
    K2006 test kit
    Jan 2017
    Monterrey, NL, Mexico
    491
    Re: AB vs DB quotes - feedback requested
    For older pools I would highly recommend AB, because of the sealing properties and is chemically neutral which is an advantage!
    7,500 gal Rectangular, Easytouch 8, Air+water temp sensors, Screenlogic2, IC40, intellibright5g color12v, Intelli pH, SD 70 filter w/Zeolit, Magicstream Laminars, waterfall. Raised Monolithic concrete lined with glass beads.
    In Sunny Monterrey,Mx!
    Mar 2017
    Brooksville, FL
    57
    The lack of start up and no need to fight pH for months are both big pluses for AB.
    K2006 test kit
    JoyfulNoise's Avatar
    May 2015
    14,083
    Ummm...based on your concerns and that fact that I've never heard of anyone setting tiles by "smooshing" then into the plaster, I'd go with the AquaBirght guy as he sounds like he knows what he's doing. I think you will be very happy with the aquaBright coating. It will be my front-up choice someday when I need to resurface my pool....
    Matt
    Mar 2017
    Brooksville, FL
    57
    Everyone in town recommends him but that 'smooshing' glass tile into the plaster bottom really threw me. I think that's common w plain ol' markers but w glass? I've sent emails to a few of the AB guys' references.
    Have you ever heard of grinding off the face of existing waterline tile to install new?
    K2006 test kit
    May 2015
    14,083
    My marker tiles were all laid down with proper thin-set tile adhesive. Maybe his method works but that's not how I would do it. And no, I've never heard of grinding off a tile face. You chip them out, clean off the old thinset and then re-tile. I can't see how grinding porcelain tile faces off is at all an easy or appropriate method of reworking a pool's interior.
    Sounds to me like this guy has just found ways to do a hack job to save himself the time and expense of actually doing it the right way....does he actually plan on chipping out the old plaster before applying the DiamondBrite??
    Matt
    Sep 2016
    Escondido/CA
    641
    I really like my AB.
    https://www.troublefreepool.com/thre...o-Acid-Washing
    My water says remarkably stable. All I do is check the balance once a week, sometimes twice. If FC is a little low, I up it 5%, if it is a bit high I lower it 5%. PH seems to just hang at 7.7. Quite amazing. I bet I could check it every 2 weeks without an issue.
    It looks great, and is exceptionally durable. I expect it will last till after I'm dead. What I also like is that if the CSI does go too negative or too positive, well so what? Worse case I'd have to acid wash my tile, or re-grout it. And leaks? I don't think that is really possible with this stuff unless there was gun play with high powered weapons. Even then, I'm not sure the AB would fail! OK, maybe it isn't bullet proof, but even in that situation, just shoot some over the top of what you have. Don't like the color? Shoot another color over the top. Since the new will melt into the old, you always have a single, uniform, and durable surface.
    Plus, the decision is obvious once you consider the following key difference:
    One is applied with a flame thrower, the other is not.
    Jon -- 28kgal, IG, AquaBright, Attached Spa, ~1990, Quad DE 80, Easytouch8, IntelliFloVS-3050, Intellichlor60, IntelliPh, Dolphin DX6, City Water, K-2006/TF-100, SpeedStir, SampleSizer, San Diego, CA
    Mar 2017
    Brooksville, FL
    57
    No chip out, he applies the new DB over the old.
    I just double checked with AB guy - he does completely remove the old tile if I choose AB. However, if I went with Marquis plaster he would put the new tile over the old.
    K2006 test kit
    Mar 2017
    Brooksville, FL
    57
    Quote Originally Posted by xyz View Post
    Yeah, but will they let me use the flame thrower? That's the big question!
    K2006 test kit
    Sep 2016
    Escondido/CA
    641
    I think this is a secret, only shared by the Knights of the Knowers of the Brightest of the Aqua. Once you learn the secret handshake, and are inducted into the Circle of trust, then and only then, will you know if this is possible.
    OR, if it is Brain, just act crazy, supply cold beverages, and you are IN!
    Jun 2016
    Martinez, CA
    241
    Sounds like the diamond brite guy is cutting as many corners as possible to maximize profits at the sake of long term reliability. If it were me, id get some more quotes if you are leaning toward DB.
    18,000 gunite pool/spa combo. Pebble tec, iaqualink rs8, cl580 filter, aquapure 1400, 400k btu lx heater, 10 solar panels, jandy 1hp, 1 1/2hp, and 2hp stealth pumps for circ, spa, waterfall
