Did you perform the following: did you test your FC after sun down record that number, then retest before sun up, and the decrease in FC was 1 or less and your CC was 0.5 or less? If the answer is yes then you are finished with the SLAM! Congrats! If not, keep on SLAMMING!
If you have finished the SLAM let your FC drop to 7. Maintain your FC between 5-7 from here on out. Never let your FC drop below 3. I would target a FC of 7. No Pucks, potions or pool store advice...just add bleach every day after testing your FC. Eventually you will get to know your pools chlorine demand and you can just add the bleach. I test about every 3rd time I add chlorine.
Your TA is a little high and your pH may start creeping up. If it does let us know in this thread and we will tweak the TA.
Congrats on your new TFP! You did a fantastic job!
