Results 1 to 8 of 8
Thread: Need Help to balance
    Jun 2016
    Acworth, GA
    49
    New liner, new water. Just opened the pool. Using TFTestKits.
    This site was great last year and we had an awesome year using the site's recommendations. We had new brick coping and a new liner put in so drained the pool. I don't want my CYA getting high like last year. Figured I'd use Chlorine tablets to bring it up gradually.
    FC = 12
    CC = 0
    TC = 12
    CH = 25
    TA = 40
    CYA = 0
    Going to add baking soda today as pool calculator says. But what about Borax? I added some last year, do I need that now?
    Ryan
    ~33000 gallon, IG, vinyl pool, 3 1/2 foot shallow with ~10 foot diving well built ~1985. New (2018) side mount sand filter. Jandy SWG (2018). Pump and Motor replaced 5/2016 with Pentair WhisperFlo 3/4 HP Fluid End pump (WFE-3 part# 075452 Inyopools) and Century Centurion 3/4 HP motor, B2847. TF-100 Test Kit, New Dolphin pool cleaner, No well, No Water restrictions
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    948
    Re: Need Help to balance
    Don't forget the CYA.
    What's your pH -you didn't include that
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    Jun 2016
    Acworth, GA
    49
    It's low PH = 7.2
    Jezza's Avatar
    Jan 2015
    948
    If your pH is sitting at 7.2 you could just add 100oz of baking soda to bring the TA up to around 50 and then see how your pH goes from there. As long as it doesn't drop any lower I wouldn't worry about the borax at this stage.
    K-2006
    Jun 2016
    Acworth, GA
    49
    Added Baking Soda and some algecide
    Jun 2016
    Walhalla, SC
    275
    Quote Originally Posted by gt6974a View Post
    Guessing you went to GT around 1996 or so? gte972z here from '01
    20x40 28kgal in-ground vinyl built 2011, liner replaced 2017
    Pentair Tagelus TA60D sand filter, Pentair SuperFlow 1HP pump, Intellichlor IC40 SWG, Dolphin Active 30i
    City water, TF-100 test kit + speedstir.
    Recommended Levels | Chlorine/CYA Chart | SLAM
    30,941
    Forget the algaecide.......wasting your money.
    Jun 2016
    Acworth, GA
    49
    Quote Originally Posted by drharris View Post
    yep
    1998-2003
    yeah, I didn't do it last year, but we used a new cover, new liner, new water so I wanted to cover all the basics.
