Thread: Above Ground Pool Steps
    Jul 2013
    Texarkana,Arkansas
    36
    Just wanted some feedback and recomendations for above ground pool steps. Thanks in advance.
    28'x52" with7' deep end AG 2hp pump 3.1 sq ft sand filter 25500 gal,TF-100 test kit
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Re: Above Ground Pool Steps
    I've had really good luck with the confer pool curve steps ( just the steps not the side piece). They have been very sturdy and comfortable to use. I'm not a small person and they feel very solid getting in and out of the pool.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,975
    I have to ask a couple of questions first........do you have a deck? What have you been using until now? What do you like/not like about them?
    Kim
    rajung's Avatar
    Mar 2015
    Iowa
    256
    Another vote for Confer here.
    I have the A frame ladder, once deck was built I ordered a adapter kit and cut the back legs off and mounted to deck.Another brand I have still in box cant remember name, will not use, way to flimsy looking.
    The Confer ones seem to be 2x strength,especially when it comes to the step treads.
    Doughboy AG 16' x 32' oval, 13,700 gal.
    AquaView by Doughboy 150lb sand filter model 0-1709-20
    PowerLine pump by Doughboy model 0-3047-200, 1.5hp-single speed-20amp
    Gulfstream electric heater-HE125-R-A
    Taylor K-2006 test kit
