Results 1 to 13 of 13
Thread: bleach vs shock for achieving very high FC
    May 2017
    Downsville, LA
    16
    hey there just wondering what the benefit is to using standard liquid bleach for very high mustard algae shock level vs using bags of shock?? 20 jugs of bleach or a few bags of shock..... Why do we choose bleach?
    Thank You!!!
    27k, rectangular in-ground, Hayward Aquarite SWG, Vinyl liner
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    948
    Re: bleach vs shock for achieving very high FC
    Mainly because it doesn't add anything else (apart from a bit of salt).
    All solid forms of chlorine either add calcium or CYA which when added can create further problems especially when they get too high.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    In a pool your size, 20 121oz jugs of 8.25% bleach will raise FC by 59 and add 98 ppm salt
    It takes 232 oz trichlor to add 59 FC. It also adds 36 CYA, 48 salt, and lowers pH and TA
    It takes 384 oz dichlor to add 59 FC. That will add 54 CYA, 48 salt, and also lower pH and TA
    It takes 294 oz Cal-hypo 73% to add 59 FC. That will add 42 CH and 60 salt.
    You can't do anything about the salt. But do you need extra CYA or CH? Raising the CYA will also raise the mustard shock level. So you'd need more powdered shock, which will raise the CYA level, which will raise shock level, and so on and so on in a hopeless spiral. Do you want to have to deal with pH and TA after you're done? CH isn't necessary for a vinyl lined pool, and adding a whole bunch at once may also cloud the water for a day or two, which makes it hard to see any progress. If you'd rather use the powder, then Cal-hypo would be the best choice, but make sure you have room for the CH. Vinyl pools won;t etch like a plaster pool but they can still get scale.
    Jul 2015
    Central Valley CA
    1,166
    As Jezza said with liquid you mostly only get FC. Most people with green pools end up here because they use powdered forms and end up with crazy high CYA leading to needing to maintain ever higher levels of FC for the same amount of sanitation. Cost can also be a benefit, liquid usually is less expensive per unit of FC delivered. So unless you know you have low CYA and/or have some shock on hand liquid is the way to go.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    May 2017
    Danville, IN
    2
    Silly question..... are you talking about regular old house hold bleach or liquid chlorine?
    Jennifer
    24 foot round, above ground pool, 22" millinium sand filter, 1.5 hp pump, vinal liner.
    May 2017
    Downsville, LA
    16
    ok wow. thanks for the info. CYA was high due to me mistakenly adding too much. CYA 115 so am partially draining now. I do have dichlor (from before finding and agreeing with TFPC!) Should i just use it since i have it? as long as I can start with not too high of CYA...... I was hoping to get it down to about 70-80 but i could even drain a little more and get it lower to compensate for using dichlor. and if i understand you correctly....Cal-hypo won't add CYA at all right? and my CH is fine @ 100
    Richard320's Avatar
    Jan 2010
    20,312
    Quote Originally Posted by TaraT View Post
    Don't use the dichlor. Just because you have it is a lousy reason. As long as the bag is sealed, it'll keep for years and years. Save it for next season when you need to raise CYA.
    May 2017
    Downsville, LA
    16
    ok it was big bucket bought from sams. already opened. but youre right i can save. so would you still recommended bleach vs cal-hypo considering i have room with my CH and Salt???? again i really appreciate your time!!
    Jezza's Avatar
    Jan 2015
    948
    Have you got Cal-hypo to use up? Can you give us a full set of test results?
    K-2006
    Richard320's Avatar
    Jan 2010
    20,312
    I recommend bleach simply because other people will be reading this thread and if they have a pile of cal-hypo leftovers they'll want to use it because you did, but they may not have room for the additional CH if they've been using it all along.
    It's your pool, so you can add whatever you want. I'd do the math and see if Cal-hypo or bleach works out cheaper. How much is 19 pounds of cal-hypo compared to 20 jugs of bleach?
    May 2017
    Downsville, LA
    16
    right will do! thanks again! have a great day!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    Quote Originally Posted by jfer419 View Post
    Yes regular household bleach and liquid chlorine are the same thing as far as active chemical is concerned. The difference between the two is usually the %.
    Bleach is usually 6% or 8.25% liquid chlorine usually is 10% or 12%
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jun 2011
    Austin, Texas
    206
    Exactly what I did. I had chlorine pucks and dichlor left over from before I found this site; fortunately my CYA never got high because I found this site soon enough before that happened. After enough seasons, I eventually used all my chlorine pucks and dichlor to maintain the correct CYA, and just at the end of last season finally ran out, and I have no intention buying any more of that.
    18 foot diameter, 52" tall above ground Cornelius pool, with vinyl liner, and resin wall caps.
    Roughly 7600 gallons
    Blue Wave "Sandman" Sand filter/pump, model NE6150. Pump is 1 HP
    Intex SWG, model # 54601E
