Results 1 to 18 of 18
Thread: Backwashing Sand Filter Too Much and Too Little
    May 2016
    Missouri
    13
    I have read and seen several videos on how sand filters work better as they start to capture materials. The idea is that the filter will capture finer material as the coarser pathways start to get filled. One video suggested that pressure should not be the determining factor to backwash the filter, and that the flow should be the determining factor. He also stated that people will call him and say that their sand filter is not working and his advice is to quit backwashing so much and let the filter run for longer periods.
    Well, I took that advice. I checked the flow every day and it seemed good. The input skimmer was working well and the output jet seemed like it was putting out a good amount of water.
    Today (5/16), it seemed a little slow so I decided to backwash. The last time I backwashed was 5/10. The backwash flow started good and then nearly stopped. I switched to rince, ran it for a few seconds, then to backwash. Same thing. The flow was very low and the filter head pressure was very high. Also significant amount of sand also came out during the second backwash.
    I opened the sand canister and found a compact layer of material about 1/2" to 3/4" thick on top of the sand. It had broken up a little from the backwashing, but for the most part it was still solid. It had the constancy of wet cardboard. I suspect that it was tree pollen. We are surrounded by 100's of oak trees and around this time of year everything gets coated with it.
    So, lesson learned. Maybe this time of year is not a good time to wait so long between backwashings. Or maybe I took some bad advice. No harm no foul. Lost a little bit of sand, but I have more.
    Cheers.
    22' Round Intex Above Ground, 11,000 Gallons, 16" Intex Sand Filter, Manual Chlorination, Taylor K-2006 Test Kit, Hang Over Edge Intex Skimmer Basket.
    Oct 2016
    Phoenix
    203
    Re: Backwashing Sand Filter Too Much and Too Little
    I have an aerator port on my pool that I leave on all year but at a very low flow rate. It squirts up and out about 8". With just a glance, I can tell if the flow through the filter has fallen significantly by looking at the reduced arc of the water spray. When the spray is reduced too much, I do a backwash.
    Dave in Phoenix, AZ, USA
    12,000 gallon IG (5' max depth) , Pebble-tec,
    Hayward SP2303 Maxflo 1.65 HP, Triton TR60 sand filter, 1 skimmer, Pool Devil skimmer, 3 returns, 1 aerator port, Navigator suction-side sweep, Hayward valve actuator, Rainbird sprinkler timer used for valve automation and chlorine injection. Softened water used for makeup.
    May 2016
    West Bloomfield, MI
    757
    Interesting. When was the last time your filter was deep-cleaned? Is it possible that remnants of floc or other agents have been building in the filter? I would think that if sand filters couldn't handle pollen that cartridge and DE filters would be even worse and pool owners throughout the globe would live in fear of trees!
    Have you ever added DE? I'm a fan. A little goes a long way (and it's not expensive in the first place). It puts us in control of the "granularity" of sand filters instead of waiting for dirt/debris build-up.
    12,000 gal Diamond Brite indoor​ pool. Pentair Triton TR-60 Sand Filter +added DE, Lochinvar Energyrite ERN-200 gas heater, Pentair Multi-valve, Pentair SuperFlo VS pump, TF-100 kit, Pool Math App - iOS
    May 2016
    Missouri
    13
    The sand filter is brand new.
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,823
    I backwashed at the end of September. I have not backwashed since then and will probably not backwash until September again. Personally, I use socks to pick up debris before it gets to the filter. My pool is in ground. I personally recommend not backwashing unless the pressure rises 25% to 30% from normal starting pressure. My water is so crystal clear, that people think that something special is going on, when in reality it is the filter and the TFP method.
    Then again, most people who really do not understand backwash every time they vacuum, which is not a good thing. If you have good flow back to the pool and the pressure has not risen, then no need to backwash.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    May 2016
    West Bloomfield, MI
    757
    What about what might be in your water...?
    May 2016
    Missouri
    13
    Quote Originally Posted by Catanzaro View Post
    I like the idea of the socks. Where do you put them and where do you get them?
    Quote Originally Posted by Rollercoastr View Post
    Whatcha' mean?
    May 2016
    West Bloomfield, MI
    757
    Quote Originally Posted by tifford View Post
    Whatcha' mean?
    I'm looking for an explanation of why something/pollen clogged your filter with the wet cardboard-like substance. Floc would be an example.
    May 2016
    Missouri
    13
    Ah... Good question. I added 2 oz of Floc on 4/25. Backwashed on 4/26, 4/30, 5/10 and today 5/16. The pool has been clear since about 4/28. Nothing else except 10% chlorine and 1 lb of CYA. Free chlorine has been around 5 except for the last few days it has been low and and untested. Water has stayed clear.
    May 2016
    Missouri
    13
    May 2016
    West Bloomfield, MI
    757
    yech! Hey - take a match to that stuff. If it lights, you may be the inventor of the next generation of bio-fuels! Wait, it was my suggestion... make that WE will be the inventors....
    (or it's some chemical goo from the pool $tore that will give you 2nd degree burns and you'll sue me. forget that match idea after all)
    May 2016
    Missouri
    13
    Or it could be a new food. Soilent Brown.
    May 2016
    West Bloomfield, MI
    757
    I definitely won't ask you to share credit for that! lol
    Catanzaro's Avatar
    Jul 2014
    2,823
    https://www.amazon.com/dp/B0716C2K5T...332220_TE_dp_2
    Some of the guys use hair net type of socks, which work well. I can not find the location, but remember them being on amazon as well. The regular socks, although more expensive capture a lot of debris before it gets to the filter.
    https://www.amazon.com/gp/product/B0...393295011&th=1
    These are the other type you can purchase on Amazon.
    May 2016
    Missouri
    13
    Thanks Catanzaro. I will definitely give those a try.
    May 2017
    NLR/Arkansas
    7
    I definitely notice a reduce flow when it's time to back wash. The SWG will also start flashing red
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    10,728
    Did you vacuum to waste when you used the floc? It should not have ended up in your filter because it can really mess it up. Did you get it all out of the filter while you had it open?
    Love TFP? Become a
    TFP Supporter!
    May 2016
    Missouri
    13
    Quote Originally Posted by zea3 View Post
    I didn't have any "fall out" from the Floc. But I did vacuum to waste initially. I really didn't see any improvement after using the Floc either. It was cloudy and slowly cleared over time. I expected a radical change in clarity but didn't see it.
    I scooped it all out of the sand filter by hand, along with some sand. I'm not sure how long the Floc hangs around, but I didn't think it was a factor in my sand clogging. But, I won't risk it in the future. I only used it because my wife purchased it instead of CYA. (It looked the same to her.)
