Thread: Step Repair
    May 2017
    Winchester, VA
    2
    Step Repair
    We're having our liner replaced, when they came out to get measurements the crack on the side of the step was found. We're in Northern Virginia and having trouble finding someone to repair it. Does anyone have any suggestions on how to do this?
    Thank you
    Sep 2013
    Nashville, TN
    405
    Re: Step Repair
    In the past there has been mention of talking to a boat repair person.
    18x36 Vinyl, sports depth, 8' Roman steps at each end. Hayward 1.5hp 2speed pump, catridge filter, 2 skimmers, no main drain, 3 SR Smith Treo LED lights
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Step Repair
    Welcome to TFP!
    Most vinyl pool steps are made of fiberglass, as are boats and corvettes.
    Here are some good threads on step repair.
    Steps
    Crack in steps causing water to leak a lot
    Crack in step
