Thread: intex ultra frame pool 18 x52 round air jet valve
    Apr 2015
    Waukesha, Wi
    27
    I just purchased a new 18 x 52 round intex ultra frame pool. It came with an air jet valve with a cover that attached to the plunger valve hose that returns to the pool. My question is do I leave that cap on the plunger valve when running the pump or do i remove it. I checked everything in the books and videos provided, but it makes no mention of this. Does anyone know the answer to my question?
    Jun 2015
    Stockholm, Sweden
    261
    Re: intex ultra frame pool 18 x52 round air jet valve
    Pictures please!
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    PoolMumsy's Avatar
    Apr 2017
    Ft Worth, TX
    36
    Pretty sure this is what you're referring to, and as you can see, I have mine off. The Auto Cleaner didn't work properly when I left it on and I just left it off. Pretty sure it's the air source for the water IMG_1685.JPG
    aeration.
    Interested in responses as this was a replacement valve that came with my 2500GPH pump upgrade to accommodate the Intex Auto Cleaner.
    Intex Ultra Frame 18' x 52" pool, Intex Krystal Clear 15k SWG, Intex 2500GPH pump , Intex Auto Pool Cleaner
    Previously owned an in-ground gunite pool /hot-tube with a Nascent Oxygen Generation purification system. Frankly, it was the bomb, but grateful for Intex.
    Apr 2015
    Waukesha, Wi
    27
    That's exactly what I was referring to. I decided to leave it off also.
    The other question I have is that I have a little silica sand in the bubble that is see thru for the backwash. Should there be sand in there?
    Apr 2015
    Waukesha, Wi
    27
    Thanks
    PoolMumsy's Avatar
    Apr 2017
    Ft Worth, TX
    36
    Welcome.Have fun!
