Results 1 to 7 of 7
Thread: Bands on filter cartridges
    praz's Avatar
    May 2017
    Surprise, AZ
    14
    Hello All,
    I have a good 50% of the bands coming off/already off of my filter cartridges. If it is relevant, I have a Hayward Swimclear C4025 Cartridge Filter with 4 large cartridges. I read on a thread here about someone who was repairing/re-gluing the bands with a hot glue gun while the cartridge was out for cleaning, and he was generally having good success. I did find this on the internet, but without any real supporting evidence: "Those support bands, typically included on cartridges 12 inches and taller, are crucial to maintaining the integrity of the pleats."
    So, I guess my questions are:
    1) Are these bands important?
    2) Can they be restored via tightening and gluing with a hot glue gun, or is the damage done once a band has come loose in the first place?
    3) If the band is missing entirely, can it (should it?) be replaced with the bands that usually hold shipping palettes together (seems to be the same material)?
    4) I don't have a glue gun (though I know they are inexpensive) and I don't have any replacement bands just sitting around the house. Should I not worry about the bands or should I make a concerted effort to fix/replace them?
    Thoughts?
    - Paul
    Paul - My Pool (Surprise, AZ): 12K gallon in-ground combined PebbleTec Pool and Spa, Waterfall, and aerator
    2 HP Hayward Super Pump II, Hayward Swim Clear C4025 Cartridge Filter with 4 cartridges, Hayward H-400 Heater, separate skimmer and vacuum connections
    Useless PebbleTec SWG System (needs T-15 TurboCell)
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,965
    Re: Bands on filter cartridges
    When I had a cartridge filter I had two sets so I could switch them in and out. Over time the bands gave way but I kept on using them. It was not until the pleats started coming apart from the top/bottom flat part that I needed to replace them. So long as there are no holes I think you are good to go!
    Kim
    wjr75's Avatar
    Jun 2013
    IL
    866
    Some of mine came off after the first year on my Sta-rite filter. I'm pretty sure the only reason they are there is for during the manufacturing process to keep the pleats in place prior to placing the top and bottom of the filter.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Agreed, they don't seem to matter one way or the other. The water is flowing from outside to inside so it isn't structural.
    praz's Avatar
    May 2017
    Surprise, AZ
    14
    Awesome, thanks for the responses. For what it is worth, it does seem to be easier to clean the pleats and get the junk out from between them when the bands have broken...but I was wondering if, conversely, that would allow more "crud" to escape back into the pool during normal operation, since it doesn't get trapped as securely in the folds of the pleats.
    Regardless, I've got enough other things to worry about right now, so I'll be leaving the bands as they are - on or falling off or gone.
    Thanks again!
    - Paul
    Mar 2015
    Sugar Land , TX
    446
    Just thinking, could you just put a oversize zip tie around the filter and accomplish the same thing
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    Jul 2012
    Tallahassee, FL
    33,965
    Maybe.........one of those large ones from the AC parts section in Lowes. I use them for all kinds of things!
    Kim
