Thread: 10 ft pool how do I get up high enough to tile it?
    Jun 2016
    Southern California 562
    96
    So I'm working on my remodel and want to start working on tiling it, I have some experience with my bathrooms and kitchens, the one thing stumping me is how do I get high enough to tile it. I don't think reaching in from the top will work... any ideas?
    Feb 2017
    Las Vegas
    885
    Re: 10 ft pool how do I get up high enough to tile it?
    My pool is a little deeper than 7 feet and my tile guy is using a type of scaffolding
    current build<--free form gunite 34x21 18k gallons 4ft-7ft deep,Pentair 3HP VSP, wisperflo 2hp, 520 cartridge filter, 400k heater, ez touch 8 with screen logic, ic40 swg. 4ft sheer decent, 2 led deck jets, 5 globrite leds,rock spa waterfall. Mocha travertine deck, noche coping. Tropics blue custom mix with LOTS of beads and shells
    Meowloud's Avatar
    Mar 2017
    Chattanooga, tn
    199
    You could rent scaffolding, or do as Big Will's contractor. Personally, I build a 3-part wood piece to paint stairways with the ladder, and pressure wash on a slope. You can google or pinterest ideas for an angle support.
    ~22k IG Vinyl (Ocean Midnight), Hayward Tristar 3200VSP, Hayward Sand Filter S3103S, Hayward 4.0 LED, TF-100, High-Iron, 7.5 ph Well Water.
    Esloser's Avatar
    Jun 2016
    Millville, NJ
    507
    My guy had some things that hung over the side of the pool.
    36,000 Gallon Inground (IG) Gunite Pool with Spa and 12" tanning ledge | White Plaster | Cartridge Filter | Hayward Single Speed Pump (x2) | 400k BTU Hayward Heater | Hayward ProLogic Automation | Taylor K2006 Test Kit | In-pool Cleaner | August / September 2016 Build Date | Build Thread
    Apr 2017
    Coastal, WA
    17
    I have a 10' deep pool and had to come up with lots of different ideas. For the bulk of the work I installed roof jacks (for installing roofing) by drilling into the pool and using expansion anchors that fit the roof jacks. After I just grouted in the holes before we sealed it.
    After sealing I built a few a-frame with a horizontal kicker - first picture above that I could move around. My pool has the slope like yours so in the sloped areas I padded up and rigged a 6' fixed ladder with a couple of angles to hang behind the coping.
    Be safe, and if you aren't used to working perched like that, it can be pretty uncomfortable. It was for me.
