Results 1 to 10 of 10
Thread: Matt from Central Arkansas. Dow flake ice melt for calcium? 83-87% Cal Chloride
    May 2017
    little rock/ ar
    19
    Just wondering if I can use this stuff? Previous owner left a big bag. If not, what should I use? What's the difference? I read another thread about this, but seemed more opinion and less fact. Has someone used snow melt for calcium for a long time. My main concern is the 13-17% that's not Cal Chlor. Also, if something else is recommended, what's it composition.
    Thanks!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Matt from Central Arkansas. Dow flake ice melt for calcium? 83-87% Cal Chloride
    Welcome to TFP!
    Yes, it is fine to use. More here, Pool School - Recommended Pool Chemicals
    Dec 2014
    Rockville, MD
    78
    Ice melt works fine. I used this stuff from Amazon. Free Shipping, 94% Calcium Chloride. I premixed it in a bucket before adding it to the pool. Makes a nice steamy soup.
    Pool: 40x15ft "Mt. Lake" shaped plaster IG (30k gallons with Borates)
    SWG: Circupool Si-45
    Pumps: Hayward MaxFlo VS (SP2302VSP) + Booster Pump for Polaris 180
    Robot: Kreepy Krauly 830 || Filter: Pentair Tagelus TA-60D (Sand)
    Test Kit: TF-100 (with Speed Stir)
    DFW, TX
    24,974
    Yeah, better not to premix it, it gets hot! See link above on how to add chems to a pool.
    May 2017
    little rock/ ar
    19
    Thanks guys! I have added about 10 pounds already. Didn't seem to cause any problems. Maybe a little hit with water clarity. Probably gonna add another 15 pounds this weekend. Anyone else have a preferred product, let me know. I'll check out the recommended chemicals link.
    May 2017
    little rock/ ar
    19
    Just read the recommended. I didn't know that the filter should be turned off when adding salt. I thought the circulation would aid mixing/ dissolving.
    DFW, TX
    24,974
    Where did you see that? Here is what it says for salt
    Salt can simply be dumped into the pool. Spread it around a bit with a brush so there aren't any large piles, and leave the pump running for 24 hours after adding salt. If you have a SWG, it should be turned off while you are adding salt and for the next 24 hours.
    May 2017
    little rock/ ar
    19
    Didn't think through it. When we run our filter, the SWG kicks on. I'm sure I can turn it off and let the filter keep going. Sorry for the slip.
    Didn't know the SWG had to be turned off either.
    DFW, TX
    24,974
    Aha! That explains it. Yes, the salt tends to pool in high concentrations while it is dissolving and it isn't all that good for the SWG to have very high salt water going through it.
    May 2017
    little rock/ ar
    19
    Speaking of bad SWGs, is there an easy way to tell if it's working? My chlorine seems to be lacking. My thought was boost it for 12 hours. If I don't show appropriate chlorine, there must be a problem. It's crazy how many testing strips I've been going through.
    I must admit, I've been running it while adding salt. I think my system cuts it off when it's outside the workable range. I cleaned it a week ago and it looked great.
