Opening, do I really need to SLAM?
zapados
73
Merrimack, NH
Finally tested my levels after dealing with a leaky filter. It's been very cold, but my water looks pretty clear. There is some debris on the bottom which I'm going to get up tomorrow.
My numbers are:
FC: 0
CC: oops, didn't test, assumed 0 since FC was 0.
TC: N/A due to above
CH: 75
TA: 50
CYA: 30
OTO: 0
pH: 7.0
Any recommendations on first steps? Since my water looks pretty clear, do I need to SLAM?
Thanks for all your help! :)
If you don't see any algae, you shouldn't have to follow SLAM process. I would get that PH up. Use pool math and either washing soda or borax. :)
Edit
Jblizzle is right. I think we were typing at the same time. There is no harm in elevating FC upon opening just to be sure.
Cool, sounds good, I'll SLAM first, then maybe toss in a little baking soda to bring up my TA and hopefully my pH a bit.
Do you think baking soda or soda ash would be better for my TA & pH levels?
After those are good, I'll maybe toss a floater in to bring the CYA up a bit, then I'm in maintenance mode!
What do you pro.s think?
