Here are my numbers.
23500 gal lined in ground
630pm
FC 8
CC 1
PH 7.0-7.1 hard to tell
CYA 30 (top of tube and still see dot)
With my pump motor going out and weather I was late to open this year and my pool was dark green and unable to see bottom in shallow end. I started a SLAM once I got my motor hooked up on Friday it has been on 24hr since. I was able to check my cya after getting more reagent r-0013 today. I was assuming it was the same as last when I closed as it has not changed much in two years, around 50-60. I started a slam targeting 24. I have let it drop below 10FC a couple of times because of work. Now that my CYA is checked and lower, I should be targeting 12FC for SLAM, correct?
With the higher FC I have been trying to stay at based on incorrect CYA I am still very green and cloudy. I have auto cleaner running and scrub brush twice a day. Pressure has not gone too much higher from where it started, so I have only back washed once in 3 days.
Any suggestions or advice would be helpful and appreciated.
630pm
FC 8
CC 1
