Thread: Hello from Charlotte
    May 2017
    Belmont
    202
    like many others before me i wish i would have found this site sooner, first time pool owner. closed on my house about 6 weeks ago. after hundreds at the local pool store fighting a "high" phos problem used 6 bottle of phosREMOVE (ouch). the pool is in good shape. now to keep it that way and adopt the TFP way of things.
    tf-100 kit is in the mail.
    Previous owner told me at closing " just feed it tablets and toss in some PH down once a week, that's all i did"
    I've been using that Clorox pool app i know it's not the best but it got me by
    a couple questions i do have while i wait for the kit
    I have 20lb of burnout 73 shock - use it up or put it away?
    also have a 20lb bucket of the bioguard tabs - use them up or save for extended vacations ect?
    third and final question. i have about 60 lbs of Lo-in-slo dry acid. i plan to use it up before switching to MA liquid. i've been premixing it in a 5 gallon bucket before tossing it in the pool, is that a bad thing?
    app numbers
    FC 5
    TC 5
    TA 240
    TH 500
    cya 50 - this was 100 but rain and 15 million backwashes with the phosremove i think i exchange enough water to lower it
    28000 IG vinyl, Jandy VSFHP165, Jandy TruClear SWG, Dolphin Nautilus CC, TF-100
    TomGallopavo's Avatar
    Apr 2016
    Hillbillyville, MO
    175
    Re: Hello from Charlotte
    Your pool is beautiful. Welcome! I'll let the experts help you but you are at the right place. Soon you will have the very best pool water a small amount of money can buy.
    Spring 2016 Install, 24'x54" Saltwater LX AG Round Pool (13500 gal.), AquaPro 200 SQ. FT. Cartridge Filter System 2-HP 2-Speed Pump, Solaxx Saltron Retro Jet RJ Saltwater Chlorine Generator, Aqualuminator Above Ground Pool Light, TF-100 Test Kit w/ Borate and Salt, Well Water.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    10,728
    Hi, welcome to TFP! Do not use the Burnout 73. Keep it in a cool dry place and if you ever find you are low on calcium you can use it to raise it up. At this point you are a bit high on calcium.
    Same with the Bioguard tabs, only they contain CYA and you don't need anymore of that right now either. Keep them dry and they will last until you need a little CYA boost.
    You don't have to pre-mix the low and slow, just brush the pool well after you add it to help it dissolve. How is your pH?
    Love TFP? Become a
    TFP Supporter!
    May 2017
    Belmont
    202
    7.8 right now, it goes to 7.8, i add 2lb of ph down it drops to 6.8, next day it will be back to 7.3. i do have the returns pointed to break the water trying to lower my TA
    May 2017
    Belmont
    202
    I do run the pump 24x7 also. Guess I need to look into a timer
    May 2017
    Belmont
    202
    test kit cam in posted my numbers
    https://www.troublefreepool.com/thre...witched-to-TFP
