Thread: UV stability of Santoprene tubing?
    Sep 2016
    7
    I just installed a 45mph10 Stenner pump. As part of the kit I received ~20 feet of clear (opaque, actually) santoprene tubing. Since most of the tubing run is exposed to the Arizona sun for most of the day I'm wondering how well it will hold up to UV and whether I should take steps to protect it?
    Jul 2015
    Central Valley CA
    1,166
    Re: UV stability of Santoprene tubing?
    since it is clear I wold cover it or paint it, it will likely last a year or two but might as well give it all the help you can. When you have used the spare roller tube new pumps typically come whit in a couple years you might want to upgrade to UV stable black at the same time.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Hide it with some split wire loom. Might find it at an auto parts or computer store. A car stereo installer will probably have tons of it.
    May 2017
    Austin Texas
    18
    Tagging in on this thread
    Is a 50' run with the santoprene tubing ok or should it be a hardline if one wanted to run this far?
    Pflugerville (Austin) Texas - 14,000 in ground plaster/pebble using cartridge (CV460) filtration system. Currently testing with a Taylor K-2006c test kit - Using Liquid Chlorine - No SPA or SWG. Pool was build in 2013
    Jul 2015
    Central Valley CA
    1,166
    Quote Originally Posted by LeMuttman View Post
    I think you could get a 50' run to work if the run is level or better yet downward sloping. looking at the Stenner site it looks like they are specked to prime up to 25' with a 3-5' lift on the suction side, given that I wold not think the discharge side could handle much lift over a significant distance but if you can make the discharge side level or lower than the pump I would think you will have no problem.
