Thread: Seepage pit?
    KarenNJ's Avatar
    May 2017
    Newfoundland, NJ
    223
    Seepage pit?
    So I found a old survey that shows a seepage pit possibly where the framework of the pool is going. It says on the survey, pump and abandon the pits. This was part of the old septic system. I would hope the pit was filled when abandoned but who knows? I am literally going off a original survey. Has anyone run into this? My husband is all concerned about the pool going on top of the pit. We need to dig about a foot down for leveling where the pit is supposed to be.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    10,729
    Re: Seepage pit?
    It may be a good investment to get a soil engineer to take a core sample in the area where you want to install the pool to see if it will support the weight of one when filled. Even if it was filled, who knows what it was filled with and AGPs are very heavy. You will want to make sure the ground is going to be stable.
    Love TFP? Become a
    TFP Supporter!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    34,015
    Re: Seepage pit?
    I have septic here and had it at the old house. Both places I had to put in a new drain field. We did NOT fill in or do anything to the old field. If you look at what a drain field is in the "old days" you will see it is a big trench with 8" pipe with holes in them. They put a "sock" around it then put rocks/gravel all around it to help drain the liquid out. They then filled it all back in with the dirt they took out.
    I do know they say to not drive a heavy truck over it as it might crush the pipe. That is something to think about.
    Good luck!
    Kim
    KarenNJ's Avatar
    May 2017
    Newfoundland, NJ
    223
    Re: Seepage pit?
    This is what I believe is buried. I think we might rent a machine and do the initial digging ourselves so we can find it and deal with it. What a pain. ..
    Oak Ridge, NJ, Seepage pit installation for use as a drywell in a full site drainage application | Vreeland Brothers Landscaping
    Jul 2012
    Tallahassee, FL
    34,015
    Re: Seepage pit?
    Better to make sure but YES it is a pain!
