Results 1 to 7 of 7
Thread: Replacing chlorinator with SWG
    Jun 2015
    Wamego/KS
    123
    Ok. I think I've made the decision to convert to a SWG. Not sure if I will do it this season or wait until next. Probably depends on price. What are the recommended brands/models. It sounds like I need one for at least 30,000 gallons? Any opinions on the CircuPool brand? Some good discounts on those at discountsaltpool.com. What about this one:
    In The Swim Salt Chlorinator System - Chlorine Generators
    Also...read about using a sacrificial anode. This can just be placed in the skimmer basket? Is this recommended? The only metal would be around the underwater light.
    25x16 rectangular in ground pool with vinyl liner (14,000 gal). Sta-Rite sand filter. 1HP single speed Max-E-Pro pump. Pool owner since 2013.
    Jul 2011
    Las Vegas, Nevada
    139
    Re: Replacing chlorinator with SWG
    I just installed a Jandy Apure35 system on my pool. It took me longer to add the salt than to install the whole system. I have an extra brand new one if you are interested. APURE35PLG is the model number
    Jay...12,500 gallon freeform pool and attached spa w/ Bullfrog Oscillator & ClusterSpray Jetpaks
    Jandy 2hp VS pump(main), Jandy 2hp Stealth pump(Jetpaks), Jandy 1hp Stealth pump(water features) Jandy CL-580 filter, Jandy Watercolors LED lighting, Jandy Aqualink RS8(revision MM) w/Aquapalm, Autelis Controller, Onetouch controller, Jandy Aquapure 1400 SWG, Jandy LXi 400k heater, Paramount PV3 6 zone infloor cleaning system
    Jun 2015
    Wamego/KS
    123
    This is my set up. Would I just remove the chemical feeder and add the SWG in its place?
    Jul 2011
    Las Vegas, Nevada
    139
    I would keep the chlorinator and you can add the salt cell next to it. I put the flow switch right after the pump. It's a matter of drilling 4 holes and just plugging it in. It even comes with the bond wire.
    gullzway's Avatar
    Nov 2009
    Tulsa,OK
    104
    Quote Originally Posted by Owner/Builder View Post
    Same one I have had since 2013 and it's still working great on my 17,500 gallon pool. I only run it 6 hrs/day and it maintains Cl level, but my pool is heavily shaded. I did have my flow switch fail/break(~$150) so I removed it and jumpered the flow contacts as it can only run when my pump is turned on anyway. In fact, the new model doesn't even have the flow switch as the manual says it has to be wired to the pump timer.
    17,500 gallon 18x36 gunite pool
    Hayward super II 1.5 hp pump, Hayward cartridge filter
    Jandy AquaPure Ei SWG 35K, Raypak R6350TI-E HeatPump
    Solar cover, Loop Lok winter Cover
    Artisian Antigua hot tub, Polk Atrium 4's
    Jul 2011
    Las Vegas, Nevada
    139
    The flow switch is just a little toggle switch anyways. The port that the flow switch installs into has several unused openings which would also make it easy to use a much cheaper generic flow switch.
    I am curious about hooking it to the timer though. I currently have mine connected to my Aqualink system so I would think that would be good enough to satisfy the system without having an actual flow switch. Although if your pump goes out and there is no flow then the swg could have a meltdown if it doesn't have a flow switch to shut it down.
    gullzway's Avatar
    Nov 2009
    Tulsa,OK
    104
    Quote Originally Posted by Nate1975 View Post
    That was a big factor for me as well, I was lucky to pick up the Jandy EI on clearance for about half price from inyo.
    They have a few different models on sale now here Clearance Swimming Pool Salt Systems - INYOPools.com
    I have thought about that and may replace the switch in the future. With my fairly short 6 hour run time I'm not sure how long one would have to run before being a hazard.
