Thread: Ready to slam, help please
    May 2017
    Cartersville ga
    22
    Ok Im ready to do this. Would like to start tonight, and im off for the next 2 days.
    FC 0
    CC 2
    TC 2
    PH 7.8
    TA 90
    CH 120
    CYA 60
    Id rather try to do this with the 60 cya, rather than wait. How are my other numbers? Could I start bringing it to shock level tonight with these numbers?
    or do i need to do some adjustments?
    thanks in advance!
    24x48 AG Waterway Sand Filter
    Cartersville, Ga
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,299
    Re: Ready to slam, help please
    Drop the pH to 7.2 because you won't be able to test it again until after the SLAM is complete. Just add the acid into the return flow, make a few swipes around the pool with the brush to get it really dispersed, and head straight for the bleach.
