Results 1 to 10 of 10
Thread: Should it stay or should it go ???
    May 2017
    Louisville, Ky.
    6
    We purchased our home and this above ground pool was the bonus with it.
    It needs work done to it but I cant find the manufacturer listed on it anywhere.
    Does anyone know how I can tell ???
    It may be beyond saving, ANY advice would be greatly appreciated.
    Thanks ...
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,152
    Re: Should it stay or should it go ???
    Welcome to the forum. Can you post us up some pics and give us a better description of it's "issues"?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Welcome to TFP!
    May 2017
    Louisville, Ky.
    6
    May 2017
    Louisville, Ky.
    6
    I had nine pics but it would only let me upload four.
    Am I doing something wrong ??
    This is confusing ......
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    417
    You hit the limit for non-member uploading.
    I use snipping tool to bring down file size, then post.
    13700 gal, 32'x16'x54" AG oval, vinyl, Echo Canyon II, 8500 series, Narrow Yard, Safety Fence & Stair, Sta-Rite Crystal Flow T-210WF, 44 GPM, Hayward SP1580TL 1HP Pump, Aqua Luminator, Festiva wedding cake steps, March 2006, TFT-100, Speed-Stir, Sample Sizer. Avatar Credit: TJ Townsend
    May 2017
    Louisville, Ky.
    6
    Thanks ...
    Can I go back and edit to remove them ???
    May 2017
    Louisville, Ky.
    6
    we closed and covered pool and when we uncovered the pool was empty and seems the liner may have shrunk since when we started to fill and got about 18 inches of water in and left overnight.. the next morning it had broken free liner coping in places and started pulling liner into pool. you can see that liner began to pull in pool sides as days passed and eventually ripped liner. the sides are buckled and we did nit want to drain, afraid structure would collapse. we think we can replace liner and use new coping (assuming universal) but at least one section of the wall track is bent/pulled inward and we think we will have to know pool brand to replace any track that needs it. also, we do not know if pool sides can be straightened or knocked back out with a rubber mallet or not.
    May 2017
    Louisville, Ky.
    6
    Can someone please help ????
    I cant even begin to order any replacement parts until I know the manufacturer ...
    I thought this forum would be able to answer some of the questions I had ....
    Thanks in advance for ANY advice given ....
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    You might be able to get lucky by going to the town and asking if a permit was pulled for the installation of your pool. If there is a permit record it could have info on who installed the pool and possibly what pool it is. If you can find who installed it they might be helpful in locating parts.
    I'm not sure how fixable that pool is though. By the time you get all the parts it looks like you need in the photos you are probably close to the cost of a whole pool. At least if you get the same size pool all the site work is already done.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
