Thread: Need CSI advice
    Jul 2015
    Cape May Court House, NJ
    130
    Need CSI advice
    Opened the pool yesterday and the water is a beautiful TFP clear yay! But my CSI is a bit low and I'm not sure what to do about it.
    Here are the readings:
    FC: 5
    CC: 0.5
    pH: 7.3
    CH: 225
    TA: 60
    Salt: 2800
    CYA: 70
    CSI: -.99
    Any suggestions for adjustments?
    22K 16'x40' inground fiberglass pool, Hayward Pro Series High Rate Sand filter, Hayward dual speed 2 hp Super II Pump, Hayward AquaRite SWG, Raypak 400K btu propane heater, Dolphin Supreme M400 cleaning robot, CoverPool auto cover. Also stand-alone Sundance Hawthorne 430 gallon hot tub.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Need CSI advice
    I'd let things live for a few days to see what happens with the pH. It may rise on it's own over the next several days. If you want to help it rise, you could introduce some aeration by aiming your returns upwards toward the pool surface, creating as much ripples/turbulence as you can. If that does not work, consider adding some borax to raise pH to about 7.6 to 7.8. Use small additions to approach the pH slowly.
    Also... in a fiberglass pool, like vinyl, CSI is not overly critical so don't fret too much about it.
    Isolated Spa - 345 Gallons
    30,955
    Re: Need CSI advice
    Don't touch a thing. Your numbers are just about dead on perfect.
    I am not a big fan for this very reason. Your pool is fine and chasing CSI with your fibreglass pool and your NJ location is simply not relevant.
    Jul 2015
    130
    Re: Need CSI advice
    Thanks, guys – I'll live and let live. It looks like swimming weather later this week!
