Thread: Pool Volume Question
    May 2017
    Cartersville ga
    22
    This might be a dumb question but to get the accurate water volume, do I need to actually measure how deep my water is, or just knowing how tall the sides are is enough? I found the calculator at the bottom of poolmath and wondered how exact in the depth I need to be.
    24x48 AG Waterway Sand Filter
    Cartersville, Ga
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Re: Pool Volume Question
    Water depth.
    Jun 2016
    Walhalla, SC
    275
    If you're just getting started you can estimate for now, but since you have the luxury of an AG, I'd measure whether the water tends to be and get really accurate results from PoolMath.
    20x40 28kgal in-ground vinyl built 2011, liner replaced 2017
    Pentair Tagelus TA60D sand filter, Pentair SuperFlow 1HP pump, Intellichlor IC40 SWG, Dolphin Active 30i
    City water, TF-100 test kit + speedstir.
    Recommended Levels | Chlorine/CYA Chart | SLAM
