Results 1 to 17 of 17
Thread: Clear GREEN water
    TheBraLady's Avatar
    Jun 2015
    Concord, NC
    178
    Unhappy Clear GREEN water
    Help! I know the drill...so here are my test results from moments ago:
    FC 3
    CC 0
    pH 7.2
    TA 60
    CH 140
    CYA 50
    Salt 3100
    Borates 50
    Water temp is 76
    H
    I had had some iron staining...so I put a handful of plain but C tablets in a sock and used that to run over the stains. Worked perfectly. Did that on Saturday. Yesterday was fine...but today?? See pic below:
    I also added 8 oz of this on Saturday:
    Finally I dropped a CuLator packet in the skimmer basket.
    I am am officially freaking out about this green water. My suspicion is that the 8oz liquid that I thought was a sequestrant is actually garbage. But I don't know what to use.
    Please help!
    Pool Completed 8/2015 18'x36' Gemini shape 3.5' - 8', 19,200 gal IG vinyl, Hayward Max-Flo 1.5 HP 2-speed pump, Hayward Pro Series 300-lb sand filter, Hayward AquaPlus SWG, NO Autofill, Dolphin M400 robot, Taylor 2005 test kit, 434 gal Bullfrog A7L spa
    30,954
    Re: Clear GREEN water
    Do you fill from a well?
    Jun 2016
    Walhalla, SC
    275
    Your chemical (EDTA) is an actual sequestrant, but it's not recommended around these parts because it's just not effective, especially with higher levels of chlorine. It's "phosphate free", so gets a lot of attention at pool stores, but phosphates are not the evil boogie man in these parts. 8oz (especially if it's older) will likely have no effect. Look for an HEDP sequestrant if you believe it is a metal.
    20x40 28kgal in-ground vinyl built 2011, liner replaced 2017
    Pentair Tagelus TA60D sand filter, Pentair SuperFlow 1HP pump, Intellichlor IC40 SWG, Dolphin Active 30i
    City water, TF-100 test kit + speedstir.
    Recommended Levels | Chlorine/CYA Chart | SLAM
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,838
    ^ Normally we recommend Jacks Magic Purple for SWG, but in this case since you added a EDTA product, I feel I should warn you that in some cases the two in combo can create a bit of a cloudy mess. I'd suggest you contact Jacks Magic help line, tell them what you used, and ask if they think the two products will react and how long to wait in order to minimize the possible effect.
    Metal Magic is also often recommended here, but only Jacks Purple is formulated for the high TDS environment of a salt water pool.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    TheBraLady's Avatar
    Jun 2015
    Concord, NC
    178
    Yes sir, we do. We initially filled it with trucked in water from a service...haven't had to top off much at all lately because of all the rain...
    Quote Originally Posted by drharris View Post
    I was afraid of that. The fellas that built our pool were just out a couple weeks ago to repair the flow switch on the SWG under warranty, and he left me this bottle "for free."
    Quote Originally Posted by Swampwoman View Post
    ^ Normally we recommend Jacks Magic Purple for SWG, but in this case since you added a EDTA or duct, I feel I should warn y
    You that in some cases the two in combo can create a bit of a cloudy mess. I'd suggest you contact Jacks Magic help line, tell them what you used, and ask if they think the two products will react and how long to wait in order to minimize the possible effect.
    Metal Agic is also often recommended here, but only Hacks Purple is formulated for the high TDS environment of a salt water pool
    Thank you so much for chiming in! I was hoping to hear from you. It is just unreal. The pool was literally perfect yesterday. And then this morning I almost spewed out my coffee!! My local pool store only has the Magenta Jack's on hand. She tried to tell me that was the one I needed, but I didn't trust it. I was thinking the Purple was what I needed. I'll call their help line first.
    If the Purple Jack's does cloud the water - would it just be a wait and see? Or would I need to SLAM?
    I can't thank y'all enough. Love this site!!
    TheBraLady's Avatar
    Jun 2015
    Concord, NC
    178
    Ok - just got off the phone with the fella @ Jack's. He doesn't think the "other" stuff I put in will have an effect.
    I'm off to Amazon!
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,838
    Hi there. Please forgive my atrocious ipadian errors in the previous post
    You are correct tat Jacks Magenta is NOT the one meant/selected for aggressive iron sequestering...it is meant more for plaster start up
    If the tech is wrong and the EDTA and phosphonic acid interact, I do "think" ( but don't know for certain) that they will resolve in a few days without a slam or retreat. I do recall a poster who had that type of interaction and it resolved after 3-4 days. But that is entirely heresay so ymmv.
    Helpful Links:
    30,954
    Before my eyes, my well-filled pool would turn green and remain so for 3-4 days each spring.
    The iron from your well water stays in solution until you introduce a new dose of chlorine. the temporary jump in pH as a result of the chlorine precipitates the iron into visible tiny particles.
    As the pool pH comes back to normal, the iron goes back to solution.
    The sequestrant will probably help speed it up but you don't HAVE to use it in this case.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,838
    ^Dave, your experience makes me wonder if we'd be better off advising people with sand filters to first try to wait 2 or 3 days to see if it will filter out instead of sequestering immediately per the AA treatment instructions, but I think the fear is that if someone has done the AA treatment to reduce stains, their foremost interest is to avoid having the stains return. What we don't know is how quickly that happens when the metal has been liberated from the surface and is oxidized in the water
    Helpful Links:
    TheBraLady's Avatar
    Jun 2015
    Concord, NC
    178
    What a difference a day makes!
    The pool definitely looks a little better this morning. But what surprised me most is that the hair nets that I keep in my skimmer baskets have caught a lot of the iron! (I think.)
    Here's what the hair net looked like just now when I changed it out, and how the pool looks this morning. It's not a full sun photo, but I can tell a difference...
    So now I wonder what I should do?
    I have a couple bottles of the Jack's Magic Purple Stuff on the way - it will be here on Thursday.
    Also - the tech at Jack's recommended raising my calcium level. It is currently 140ppm. He recommended raising it by 100 up to 250-ish. His reason was that the water is too soluble because of low calcium...thoughts?
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,838
    That's what I was wondering in my comment connected to Dave's observation...that maybe you're better off getting as much out via filtration first to reduce the overall iron load...because oxidized iron will filter out via sand and, as you've learned, stuffing or hair nets in the skimmer.
    If right nw there is no mild staining coming back and you can keep your ph on the lower side, I'd eep filtering. When the Jack's come and if the water is pretty clear, you migh add just a maintenance dose instead of start up, and just add a bit more as soon as or IF you notice a slight discoloration on your stes. Eg. Use as little Jacks as you can get by with
    The black tinge on hairnet also Akers me wonder if there's a bit of maganese or copper in there too. Not sure about reactions from your EDTA product.
    Re calcium...I found it has helped "carry out" more metal to increase ch a bit, also per Jacks tech and another tech in the industry. But before adding anything new, give it a bit more filter time, add some ch, then apply a bit of Jacks I think.
    Helpful Links:
    TheBraLady's Avatar
    Jun 2015
    Concord, NC
    178
    I've been thinking about where the metals have come from. I'm going to the pool store today to have 3 samples tested. One from the pool, one from the hose, and then one from the hose WITH my metal trap pre-filter. Will be very interesting (I hope) to see what the results are.
    We live back about 1/2 mile into the woods and our pool sits to the side of our home. We have a very long gravel driveway with car haulers in and out daily, as well as the neighborhood kiddos riding thru occasionally on 4-wheelers. I wonder if the dust that is stirred up and ends up in the pool could be contributing to the metals? When I run the robot I always have a little "mud" for lack of a better word - so I know the dust from the driveway ends up settling in the pool...not a thing I can do about it, but nice to know the source I guess...
    Truly - thank you so much for your help. I really appreciate it! And I like the advice about Jack's! Expensive stuff!
    So you think I should leave the pH alone at 7.2? I was planning to raise it a touch. But maybe it will take care of itself.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,838
    I'd leave it at 7.2 for right now to prevent staining since the metal isn't as sequestered as its going to be
    Helpful Links:
    30,954
    Why would you think they are coming from somewhere other than your well? That is almost surely the source.
    TheBraLady's Avatar
    Jun 2015
    Concord, NC
    178
    Ok - so I took 3 water samples to the pool store for metal testing.
    1st sample was pool water
    0.1 iron
    0.1 copper
    2nd sample was water directly from the hose
    0.4 iron
    0.4 copper
    3rd sample was from the hose with my pre-filter attached
    0.1 iron
    0.2 copper
    So - based on those results I don't feel like the pre-filter is a waste of money at all. At least it decreases the amount of metals to some extent, and I think something is better than nothing...
    The pool looks terrific. The hair nets in my skimmers look much whiter. This morning's test results were
    FC 4.0
    CC 0
    pH 7.4
    TA 60
    CH 140
    CYA 50
    Salt 3100
    Borates 50
    Temp 80
    My shipment of Jack's Purple Stuff came today as well. My plan (since the water looks great and I don't see any more stains yet) is to add a maintenance dose. The bottle indicates this would be between 6-8 ounces per 10K gal. It does not say how to add it though. It does say that I "need" a Jack's Sequest Test kit to determine the ppm of "Stuff" in the water...they are recommending 10-12ppm.
    I also would like to increase my CH level...by 100ppm - as per Jack's tech recommendation...
    Thoughts?
    And thank you very much!!
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,838
    I just pour it right on the steps...it will mix in fine, and if there's any faint discoloration on steps it will brighten them Your plan makes sense to me.
    Your pre-filter is doing its job and accords with my own experience
    Helpful Links:
    Jul 2014
    dallas ga
    171
    Swampwoman!
    Yay. so happy to find you here. I am struggling. AGAIN. three years ago I was in here struggling. I have not opened the beast in the backyard until now. The shame is great. I PM you and asked you to take a look at my info and offer your wise opinions. See PM for link
    thanks!!!!
    In Ground. Vinyl lined 23,000 gals. Sand Filter. Hayward. Built 1991
