Thread: Hayward Goldline Aqua plus menu button no tworking on panel.
    May 2017
    Campbell Hall / NY
    1
    Exclamation Hayward Goldline Aqua plus menu button no tworking on panel.
    All my other buttons seem too work except the menu button. Anyone know why and how to fix?
    Panel is only about 4 years old.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Hayward Goldline Aqua plus menu button no tworking on panel.
    Welcome to TFP!
    I cannot help with your question but hopefully a will help get an answer.
    Sometimes the buttons become unresponsive. The only fix that I know is to replace the display board.
    GLX-PL-LOC-P-4 (Display, Local, AquaPlus)
    Support the site
    JoeGolan's Avatar
    Nov 2016
    Palm Coast, FL
    200
    In looking at your panel, it seems like it was hit with water at some point. I had a similar issue
    This repair sort of comes under Murphy's Laws....go ahead and try it, if you break it you had to replace it anyway
    Turn off the power to the panel
    Remove SWG cord
    Remove the 3 screws holding on the steel plate
    Remove the display board (it sits on 4 nylon posts) and unplug (be sure to note orientation of wires, I don't think it was keyed)
    Remove the screws holding in the pc board to the display unit and remove it
    "button" pad will then be exposed, carefully peel back and look for discoloration/corrosion on the contacts
    Clean carefully the pc board "contacts" with some q-tips dipped in alcohol
    For heavier oxidation, try a pencil eraser but do not rub too hard - do not scrape with a sharp metal object or sandpaper
    Clean rubber "button" pad with alcohol and let dry before reassembly
    Power it back up and see how you made out
    Here is a youtube video on cleaning the contacts for another piece of equipment to give you an idea how to clean the buttons, the principals are the same
    How To Repair Remote Control Buttons That Dont Work - YouTube
    I'm a black and white type of guy ... the only gray in my life is the hair on my head
    750 gal fiberglass built in spa with Hayward equipment. Pump is SP3010X15AZ Control is Aqua Plus with a T-cell-3 SWG and a H400FD Heater, Hayward C12002 cartridge filter filter
