Plumbing VS Electric .. Underground Preference?
LizzyA
0
May 14, 2017
10
Northeast Ohio
Hi All,
We live in the Cleveland Ohio area, so our frost line is 42". We are putting in an 18' x 52' AGP and I would prefer to have the pump and filter in the "pump room" which is off the garage and was built specifically for pool equipment (there was an old pool on the property before we bought it which has since been taken down). We just had this pump room brought up to NEC code with the intention of putting the equipment in there and running the piping underground to the pool. Now my husband is changing his mind! :(
He now wants to run the electric underground to the pool and have the GFCI outlet installed out there. He says the electric line only has to go down 18" (waiting to hear back from our electrician on this) but the plumbing lines would need to go down to the frost line. I've read different things on depth of piping so any info from this expert community of pool owners would be much appreciated!! This is all new to us! :kim:
Is there any preference or reason to go one way or another? We have about 30' distance from pump room to pool.
My husband can run the plumbing (so that will save us money), whereas we would have to hire the electrician again to run the electric and install a GFCI out to the pool. I'm all about saving the money but will do what makes the most sense in the long run.
Thanks Everyone!
Lizzy
Thanks! I thought that I had read somewhere it's more like a sprinkler line and can go as shallow as 10 inches. I read somewhere else that this guy only put them down 6 inches and he lived in upstate NY. So, as long as you winterize properly, and don't run any lawn aerators or heavy equipment, it seems like shallower depths are okay? Just wondering what the general consensus is on this. Or if there is an "insider" rule of thumb. Thanks Everyone!
Hi. My personal preference would be to have the equipment in the room shielded from the elements too. That being said you should have a GFCI outlet within X distance of the pool. Even if your town code doesn't require it, it is an important safety item. My town requires one no closer to the pool than 10 feet, no more than 20 feet. Not sure what the NEC says but follow that if you don't have a town regulation on it. If you have a standard outlet in that location already it is easy to swap out with a GFCI. Another thing to consider is the bonding of the pool. My above ground pool had this so you might need an electrician to run the bonding wire to the pool so don't backfill/burry the pipes until you know for sure. Would stink to dig another trench just for that.
If you're digging for the pipe might as well put another in there for outdoor speakers. Hook up a Sonos Amp or Google audio cast thing and you can play music from your phone/tablet without lugging a radio in and out.
This is all really great..thanks!! Helps make my case for the pump room!.. LOL :kim:
Yes, thanks! We're going to bond. Good catch about that reciprocal outlet too. I remember reading that's a requirement (we fall under NEC 2014) and we have one, but will have to check the distance on that. :smile:
I'm about to relocate my pump/filter about 15 ft away from the pool to the corner of the fence. I'm putting the pvc piping underground about 18". The depth was somewhat arbitrary except that is what I was trenching the electrical conduit at. Come winter, I'm going to disconnect the piping and blow out the lines to prevent freezing.
Put some extra unions / valves in the line to make life easier.
Well, 6" might meet code, but that's REALLY shallow, in my personal opinion.
Also, having dug up 35 year old rigid metal conduit near to the pool environment, I would NOT ever install it myself. It rusted completely down to nothing. I'd prefer PvC, even if it requires digging another foot deeper.
