Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Longest You Have Gone without Needing to SLAM
    Apr 2017
    Phoenix
    500
    I know that if you keep your water balanced and stay on top of adding chemicals that you should not need to SLAM your pool (except for those that close down pool in winter). However, I'm assuming (maybe falsely) that despite everyone's best efforts there will always come a time that a pool doesn't pass the OCLT or your CC gets above 1.
    With that said, I was curious what the longest streak everyone has had where they have not needed to SLAM their pool? (Not counting the initial SLAM many do each year to open their pools).
    When you did finally have to SLAM your pool what do you attribute to as the reason? Did you get lazy in adding chemicals, did you go on vacation, did you just have an algae bloom despite keeping everything balanced, ect?
    16,000 gallon in-ground pebble tec pool. Hayward SP3400VSP Eco-Star Pump, Pentair Triton 2 TR-100 sand filter, A&A 5-port in-floor pool cleaner, Pentair Intellibrite 5g color changing pool light, Polaris 965iQ Robotic Pool Cleaner, OG Pool Math Subscriber and most importantly a Taylor K-2006C test kit.
    Test Kits Compared
    | SLAM | Chlorine / CYA Chart |
    klynch494's Avatar
    Aug 2015
    Twin Cities/MN
    96
    Re: Longest You Have Gone without Needing to SLAM
    This is my third season with an above ground pool, so in no way shape or form will I claim to be an expert, as there are plenty of them here on this site, so I can only speak on my behalf...
    Since I do not put a cover on my pool over the winter, opening it in the spring usually involves scooping out a small amount of debris. This debris leaves sediment at the bottom of my pool that once stirred up makes my clear water turn green. This leads to a very short SLAM once a year that only lasts for a couple days because most of that sediment just needs to be filtered out.
    I'm very diligent about testing my water and keeping it balanced to avoid any issues. I close late in the fall bringing it up to SLAM level and open up early in the spring to avoid neglecting my pool while the water temperature is still warm enough for algae to bloom.
    Who knows, maybe one of these years I will buy a cover for it and forgo the SLAM altogether?
    Sometimes despite your best efforts, things do happen. I did have an issue last year where we took on some pretty bad storms and had some furniture blow into my pool that put a bunch of pollen/dirt and other byproducts into it. Couldn't get to it for a few days due to a crazy work schedule and more storms so I did have to do a mini SLAM there as well...
    Kevin, TFP Believer & Supporter
    (Yup, I drank the pool water)
    13.5K gal, 24' Round AG Vinyl, TF-100 Test Kit
    2HP Waterway Pump, 200 SqFt Hayward Element Filter
    Recommendations: Pool School, TFTestkits & Pool Math
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    I am starting season six this year. I've never drained a single gallon, missed a day of swimming, or had a green or even a cloudy pool. My water has been crystal clear every day since day one! Thanks TFP! But, I did have some little green fuzzy algae spots, like 10ish spots 1/4" or so, under the waterfall and on the sun shelf because my FC got a tad low. So I did one SLAM summer before last for less than a week and we swam the whole time. So, 2-1/2 years before SLAM and 2-1/2 years after SLAM. I seriously doubt I'll ever need to SLAM again.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,609
    going on 3 years. have owned pools for 4.
    The one time it happened was on purpose. I was testing that CYA reducer that doesn't work and had
    to get levels low enough for it to work, then mustard algae formed.
    Dolphin E10 Cleaning Robot.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,297
    spin,
    I have three saltwater pools that have all been 'TFP" for about three years.. I have never had a single day where my pools were not crystal clear. No algae ever...
    It is almost embarrassing because I tend to shy away from SLAM questions, as I have absolutely zero practical experience in that area...
    Keep in mind that where I live, and I assume where you live, it might get too cold to swim, but we never close our pools.
    Thanks for posting,
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    I've never SLAMmed my own pool. Closest I've gotten is to raise the FC a little and add some DE when the sparkle goes away. If it doesn't look like this (yesterday) I'm not happy!
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jul 2015
    Central Valley CA
    1,166
    Pool is 19 months old never slammed hope to never have to. Stenner pump probably gives me a false sense of security though, makes things a bit too easy, I was testing way more when manually adding chlorine.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    poolnewbies5874's Avatar
    Aug 2015
    SW Ohio
    126
    Been using TFP from day one (built in 2015) and no SLAM ever and hope I never do! We close pool in winter and follow TFP procedures and so far we haven't needed to SLAM at opening either. This year we actually had a little FC left when we opened!
    12,000 gallon Blue Hawaiian 'Hamilton' fiberglass IG 15x34 freeform, Pebble Beach finish, Pentair Clean & Clear 100 filter cartridge, Pentair SuperFlo 1.5HP pump, Stenner pump, Raypak 266k heater
    8/2015 pool build photos TFT-100 test kit
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    656
    We went four years without slamming our Salt Water Pool. When I did SLAM, it was do to a circulation problem that was mechanical failure.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Opened pool in 2014, never had to SLAM. Found it a touch cloudy last summer after much time away, but a few days of a few PPM max limit for my Cya got me straight.
    Essential Links:
    Oct 2014
    San Antonio, TX
    450
    Opened my SWG pool in 2015. I have never slammed. I do not close it, but it is covered for almost 7 months. Since my pH stopped moving last year, I have gotten real lazy about even doing the pH and FC tests...need to do that tonight. Just noticed on my pool math app that it has been almost 2 weeks
    Free form 17X30. 14,500 Gal. Pentair sand filter and 1.5 hp pump. Aqua-Rite SWCG. TF-100 Test Kit w/Speed Stir
    Apr 2017
    Carrollton, Ga
    28
    Just finished my 1st slam last week, then had to lower my FC to add stain remover (stains were there when I started the slam). As of today the stains ae gone and shave the chlorine back to 4.0. I think I'll keep the pool open year round this year just to see if I can maintain it even though I can't swim in it from about Mid Sep. to mid May. That way I won't have to buy a new cover.
    By the way, pool is now crystal clear and I think it will stay that way all summer, Thanks TFP. I found this site via you tube video's
    Approx. 19Kgal, Grecian 16'x32',IG Vinyl, Built 2-2001Sta-rite sand filter (T-200BP-1), pump/motor Hayward-continuous-3450rpm, 1HP. Polaris 380, (I rebuilt 2016), PB4-60Q booster pump 2007 replaced. Old pool cover will need replacing at end of season. City water. Hope liner last till summer of 2019
    Jun 2017
    New Orleans, LA
    90
    Quote Originally Posted by jagger2005 View Post
    jagger2005 (and anyone else who might know) -- do you find that upon covering the pool, the FC levels stay stable (or close) over the intervening months until the cover comes off?
    Like, for example, you might close the pool at these measurements (mock numbers):
    FC: 8.0
    CC: 7.9
    CYA: 50
    ... then cover the pool, wait 5 1/2 months, then measure something like this after the uncovering (mock numbers):
    FC: 7.5
    CC: 7.5
    CYA: 50
    Intex 16' x 8' x 42" Prism Frame AGP, vinyl liner, 3,300 gal, opened 5/28/2017. Intex Krystal Clear Model 637R Filter Pump. Cartridge filter (Size A). 6-way HTH testing kit.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,311
    7 years. 365 days a year. It'll be 8 years come October.
    Pool was clear when I moved in and it has never had an algae bloom. Once time I did spy some algae lurking on the grout lines right at water level inside the skimmer throat, but I just scrubbed it off with a brush.
    Oct 2014
    San Antonio, TX
    450
    Quote Originally Posted by bordelond View Post
    FC: 8.0
    CC: 7.9
    CYA: 50
    FC: 7.5
    CC: 7.5
    CYA: 50
    I run my pump 4 hours a day with the cover on it. The cover, along with short days and cooler weather, dramatically affects the FC loss and evaporation. My pH never moves as well. In these 2 years we have had a lot of rain in the off months, so I always need to add salt and CYA
    Jul 2015
    Willow Springs MO
    12
    I wanted to read these posts, since the following weekend my brother-in-law, who has had a pool for 20+ years, and I got in a conversation regarding chemical use for our pools. I told him about TFP and that all I add to my pool is bleach and a little muriatic acid when needed. He ask how often I SLAMMED. I told him once upon opening my pool (and in the 3 years since finding this site and converting from Baquacil this is the first year I've had to do it upon opening). He told me that bleach alone does not kill algae. I told him my pool was crystal clear and stayed much cleaner then most others I've seen. He would not budge from his opinion that my pool should be SLAMMED regularly. He uses the tablets and shocks once a week. I ask him why he needed to shock the pool if the tablets did their job. His response, because you're suppose too!! I had to agree with him that putting tablets in two or three times a week and sticking a strip in the pool to test would be much quicker and easier, especially when you're away from home even just a few days! BUT I love my nice clear pool and knowing what is in my pool water. The ONLY reason I would consider changing what I do is for the ease of leaving home for any period of time, without worrying what's going to happen to my pool!! I have to have my neighbor put bleach in for me every day if we are gone! My question is why does he think algae would be growing in my pool if I only add bleach and never "shock it". My sister thinks my pool is not safe to swim in because of this. BUT it is crystal clear!! It actually sparkles! I can't say the same for theirs! Also, any suggestions for when you're leaving for an extended period of time on how to keep the chlorine level up??
    17,000 gallons, Aboveground, vinyl, sand filter, Taylor K2006 test kit, Dynamo StaRite/Cristol-Flo II tank/filter. Former Bacquacil user!
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    If they don't believe you (or TFP) maybe they will believe Wikipedia:
    Many bleaches have strong bactericidal properties, and are used for disinfecting and sterilizing and thus are used in swimming pool sanitation to control bacteria, viruses and algae and in any institution where sterile conditions are needed.
    Bleach - Wikipedia
    When I am on vacation I use a floater with trichlor pucks. My CYA runs low as it is, and 5 days worth of trichlor isn't going to raise it that much in that time-frame. Any longer than say 5 days I get whoever is feeding the cats to blindly (no testing) add chlorine with the pump running and hope for the best. No troubles yet!
    Jun 2017
    New Orleans, LA
    90
    I thought a cover would keep pretty much all rain out? Or is your pool not covered continuously during the off-season? Newbie here, so I am sure I'm missing something obvious.
    Jul 2015
    Willow Springs MO
    12
    Thank you! Wikipedia it is!!
  20. Back To Top    #20
    Oct 2014
    San Antonio, TX
    450
    My cover is actually a leaf net - which is a mesh net. Rain and sand still gets in pool
