Thread: Test kit noob question
    May 2017
    Nassau NY
    28
    I currently have an HTH test kit I picked up last year for our first pool (intex- This was before I found TFP)
    https://www.amazon.com/HTH-1173-6-Wa...6+way+test+kit
    I would like to continue using it so as not to just throw it out but it does not test for FC. I'm considering purchasing this Taylor k-1001 for free chlorine and PH to supplement the HTH kit which does everything else. TC,PH,Bromine,TA,Hardness,CYA
    https://www.amazon.com/Taylor-Basic-...orine+test+kit
    Question is, is the HTH kit sufficient/ accurate enough to get me through the season compared to the Taylor setup? Should I just bite the bullet and get a full TF100 kit and toss the HTH? Buy the FC test separately? Overthinking things?
    5700 gallon AG Doughboy 12x20 oval, Intex Sand filter, Hayward Aqua trol SWG
    Long Island NY
    Doheney's jet drive robot (aquabot)
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Test kit noob question
    Since your reagents are a year old, what I would do is go with a TF-50. This gives you all the tests you need, but not a color block for TC and pH. Since you already have those in the HTH kit.
    The FC test in the Taylor K-1001 is not what you want for an FC/CC test. You want a FAS-DPD test for FC and CC that goes up to 50+ ppm so you can perform a SLAM if needed. The TF-50 has that.
    TF-50 plus your TC/pH color block you already have is the best bet imo. If you need more cylinders or more reagents, you could add those on as well. TF-50 @ TFTestkits.net
    Isolated Spa - 345 Gallons
    May 2017
    Nassau NY
    28
    TF-50 it is then. Thank you
    Long Island NY
