Thread: To keep Hayward SAS SWG
    Mar 2017
    phoenix
    14
    Hello. So I'm considering returning my Hayward basic salt and swim swg. For Circupool SJ-40. I'm on the fence about doing so. The Hayward unit is rated at .98lbs of FC a day. I'm running it at 80% for 9hrs to maintain a FC of 3-5ppm. In 85 degree weather. The 100 degree temps hasn't hit phx AZ just yet.
    The SJ-40 is rated at 1.7lbs of FC a day. With an extra $330 price tag. So should I opt for the bigger unit now that I can return the SAS unit? Or keep my $330 in my pocket and cross my fingers the SAS unit can keep up with the heat . Plus there's no solid number on how long the SAS cells last. One member stated 2 seasons. In a colder climate. SAS cells sell for $170-185. Roughly the cost of Chlorine for a year, maybe.
    its my first pool.
    Many info would be great.
    10k pebble tec pool. Hayward VSP pump. Hayward sand filter . PPC 2k In floor cleaner.
    Hayward SAS SWG.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,263
    Re: To keep Hayward SAS SWG
    A,
    In "theory" your Hayward is sized for your pool.
    It may not be a SWCG issue.. Please tell us how much CYA (stabilizer) is in your pool water???
    But, bigger is almost always better when talking SWCG...
    Mar 2017
    phoenix
    14
    I'm at 80 CYA . I guess it's going to boil down to running the Hayward SAS at 70% plus during the summer months. Or give in and get a bigger unit.
    Hayward SAS SWG.
    Jul 2014
    Bedford, TX
    9,263
    A,
    Assuming nothing is eating your chlorine, and it is all lost to the sun, then with a CYA of 80, I'd opt for a bigger cell.
    I would do the OCLT first to confirm that the sun is the only issue...
    See this... https://www.troublefreepool.com/cont...loss-test-oclt
    Jul 2014
    Bedford, TX
    9,263
    A,
    I went back and looked at this again. It appears to me that running 8 hours a day at 80% will generate about 3.1 ppm of FC.. So running 9 hours a day won't make that much difference.
    So it sounds to me like your current SWCG is working about like it should.. We generally say a pool uses 2 to 4 ppm per day...
